NCR18650GA maximum charging rate?
StorminMatt
Norcal
I can't seem to find a reliable figure for this anywhere. Mountain Electronics says 1375mA is the max (and 1000mA is recommended). But Illumination Supply lists 1475mA as a 'standard charge'. And HKJ says 1675mA is a 'standard charge'. Does anyone know the maximum rate at which this battery can be charged? Would, for instance, 2A be too much if you are in a hurry?
Tachead
Northwestern Ontario, Canada
Once again, standard charging rate of 1475mA, but NO maximum charge rate.
I wouldn't go over the 1475mA listed on the datasheet myself. 2amps is too high imo. Just keep a spare ready and you never have to be in a hurry. 1amp is a pretty standard charge rate for 18650's and will keep your cells healthy longer.
StandardBattery
MA
Datasheets for the cell have shown both a standard change rate of 1.675A with a standard charge time of 4hrs (2015.04), and standard charge rate of 1.475A with a standard time of 4.5hrs. The specification may have changed over the development of the cell. Sanyo warns that the maximum charge rate per cell should not exceed 3.35A, which is based on the battery model that the NCR-18650GA belongs to (2015.04). Standard charge rates are based on charging at 25 deg. C.
StorminMatt
Norcal
Regarding NCR18650G-H0ANA, the charging current should not exceed 3.35A/cell
So it sounds like 2A on the Rocket Charger is not a problem, especially if it is just occasionally. I'm also assuming 2A is even less of a problem on higher discharge cells (ie Sony VTC, Samsung 30Q, LG HG2, etc).
hellokitty[hk]
It's a high quality cell, I just charge at 5A.
High charge rates shouldn't be a big concern with this cell.
