New Mini MKIII's for 2021
defloyd77
Wisconsin
YES! I've been holding out for a 319A Mini since I got my Q16L with that LED. THANK YOU!!!!!!!
Pacific N.W.
  • LED Type
    Nichia 319A (4000K / 90+CRI)
  • battery type
    1xRCR123 High Discharge
  • Weight
    1.6 oz (with battery)
  • Dimensions
    Length:2.2" / Diameter: 0.8"
  • Voltage Range
    2.0V-4.2V
  • Beam Distance
    120m
  • Body Materials
    Type-III hard-anodized 6061-T6 aluminum & 6/4 Titanium
  • Window Glass
    Optical grade glass (2 side AR coated)
  • Water Resistance
    IPX8 (1m)
  • Where it's Made
  • Solid Copper (Direct Thermal) MCPCB
    Pioneered by custom makers and modders, the LED is mounted to a solid copper PCB to provide superior thermal performance and maximum output. A first for the Quark.
Got Lumens?
Champlain Valley
  • LED Type
  • battery type
  • Weight
  • Dimensions
  • Voltage Range
    2.0V-4.2V
  • Beam Distance
    120m
  • Body Materials
  • Window Glass
  • Water Resistance
    IPX8 (1m)
  • Where it's Made
Ya, What Chance just posted :D
GL
defloyd77
Wisconsin
I notice the specs are identical to the old version, down to the 120m beam distance. A simple copy and paste or is the 90+ CRI 319A completely identical performance wise to the 75+ CRI XM-L2?
Pacific N.W.
Specifications
  • LED Type
    Cree XPL-HI (4000K / 80+ CRI)
  • battery type
  • Weight
    1.8 oz (with battery)
  • Dimensions
    Length: 2.4" / Diameter: 0.8"
  • Voltage Range
    2.0V-4.2V
  • Beam Distance
    200m
  • Body Materials
  • Window Glass
  • Water Resistance
    IPX8 (1m)
  • Where it's Made
r.d.hewitt
Pacific N.W.
I'm assuming acrylic optic under ar coated glass on the non-turbo ?
I'd just be guessing, but perhaps this will lend a clue to the more trained / knowledgable eye.
That is the most recently purchased MiNI MK III.
Edit / Addendum - Yes, there's an optic, but I'm not positive of the material it's constructed from.
nbp
Wisconsin
I sure don't need another light, but I like my blue Quark so much I might have to get a blue Mini to match. I love the emitter, but wondering if the beam is a similar nice smooth punchy flood as the Quark, or if that optic collimates the beam more than I would like. If the optic is the same as the previous model, can anyone comment on the beam pattern compared to the MKIII Quarks? Thanks.
