The 2 second turn-on delay problem remains. Very irritating!
I got mine in the mail yesterday, and I agree wholeheartedly -- 2 seconds to turn on is too long. Since the buttons are so small, I'm not positive I'm actually pressing the power switch properly, and this uncertainty gets magnified by the power-on delay.
Having carried the TIP for a while, I got used to locking it out after every use by holding down the two buttons simultaneously in order to avoid accidental activation... which is admittedly clunky, but I still found it to be a better UI in practice than the TINI's power-on delay.
The much bigger problem with the TINI, however, is the lack of waterproofing and dustproofing. My expectations were not very high -- meaning I had no plans to dunk it in water on purpose -- but when I turned it on last night, I could see
light coming out through the seams in the body and behind the bezel. :thumbsdow Dust and lint from my pocket will certainly get inside the light, and drop into a puddle would likely be fatal. I don't have much faith that the internals will stay dry during normal use in the rain either.
Perhaps I got a bad sample with poorly-made or poorly-aligned parts, but in any case the design should have included some sort of gasket to prevent modest exposure to the elements. That might have added $1-$2 to the cost of the light. I'm glad that they covered the charging port (that should have been included on the TIP IMHO), but the rest of the body being unsealed undermines that improvement completely.
Since I foresee the light having a very short lifespan, I plan to return it unused.
