New released IMALENT DM35 LED flashlight 2000lumens with sleeping tight light
imalent
Shenzhen
Product Introduction
The Imalent DM35 is a rechargeable flashlight with compact size but high performance. Only 115 mm in length, this compact body emits a max output of 2000 lumens and beam distance of 450 meters. It uses one micro USB rechargeable 21700 Li-ion battery. Included magnetic tail cap which can release your hands free for working. In addition, the indicator on the switch displays real-time battery status, 5 output levels plus strobe mode, cater for daily use, outdoor activities and repair work.
Product Features
  • Utilizes one CREE XHP35 HI LED. The lifespan up to 50000 hours with maximum output of 2000 lumens.
  • Thanks to the integrated clip and magnetic tail cap, the DM35 is perfect for hiking, campaign, machine repairs, and other activities where regular lights fail.
  • Built-in one micro USB rechargeable 21700 Li-ion battery
  • Sleep tight light: Our DM35 emits a red light that helps you sleep. Emitting red spectrum lights between 590~610 nm wavelengths helps your body create more melatonin that gives you a relaxed and pleasant feeling that helps you get deeper and better sleep.
  • Tail stand capability
  • Product size: 115(length)*33(head diameter) *25.6(diameter) mm
  • Net weight:87g/160g(battery included)
  • High efficiency constant power circuit will maintain constant brightness
  • Built-in thermal control module will automatically adjust the brightness output according to the working state and outer temperature
  • Combination of toughened ultra-clear mineral and anti-reflective coating glass
  • Aluminum OP reflector
  • Aerospace-grade aluminum alloy body, wear-resistant Type III hard-anodized surface treatment
  • IPX-8 standard waterproof (2 meters submersible)
  • 1.5m impact resistant
  • IMALENT Official store:www.imalentstore.com
