NEW Rofis TR18 1100 Lumens Magnetic Adjustable-head Portable Compact LED Fla
rofisbenny
Dear all, the Rofis TR18 will coming soon. Details below:
Features
•Adjustable-head flashlight, multi-functional usage
•Detachable magnets tail
•Utilizes a CREE XP-L HI V3 LED
•Maximum output of up to 1100 lumens
•Boasts a peak beam intensity of 4673 cd and a throw distance of up to 136 meters
•Innovative single button offers access to five brightness levels and three special modes
•High efficiency constant current circuit provides max runtime of 320 hours
•Integrated power indicator light displays remaining battery power(only available when 18650 lithium battery is use )
•Memorized Function ability
•Direct access to moon output
•Ultra compact and lightweight (diameter 24.5mm, length 118mm),net weight 69.5g (without magnets tail and clip)
•Switch incorporates a specially designed lock function to prevent accidental illumination.
•Reverse polarity protection prevents damage from incorrectly inserted batteries
•Constructed from aero grade aluminum alloy with HAIII military grade hard-anodized finish
•A micro-textured reflector offers wide angle lighting
•Waterproof in accordance to IPX-8 (two meters submersible)
•Impact resistant to 1.5 meters
•Tail stand capability
Output & Runtime
Turbo: 1100 lm~550 lm/30 sec~2.3 hrs High: 228 lumens/5 hrs
Medium: 58 lumens/20 hrs
Low: 17 lumens/67 hrs Lower: 2 lumens/320 hrs SOS/Strobe/beacon
Thank you for reading. Any questions please send email to [email protected] .
LightObsession
So, this will be a little bit shorter and have a wider angle and floodier beam profile? Will it have much of a hot spot?
rofisbenny
Yes, this light will be more shorter than TR20, and it with a beam angle of up to 90 degrees, the head can be rotated 0-150 degrees. As we use a micro-textured reflector, so the max peak beam intensity is 4673cd, the beam will more softer and bigger.
