Re: Need update on decent Fauxtons
No soldering required. All they are is two 2016's straddled by the LED leads, which have been bent to go around the batteries. The tinkering is usually adjusting the bend of the leads, if it comes on bright but not reliably, especially while using the constant on switch, which just slides over to apply pressure to one lead. If it is dead, it probably needs new batteries. That's when I just put in a new 2032. It won't be as bright at first, but the 2016's will dim to it's level pretty quickly, and it is still quite useful, and lasts many times longer than the 2016's.
Cool necro-thread, and it reminds me how long I have had the same 2032 in my Photon Freedom, four years! In fairness, I have been starting to think about a new one, as it is quite a bit dimmer than four years ago, but still works great. Hoping I don't have too tough a time, as per the above discussion. It took a while to get it to work with the 2032 back then.
