Olightworld
- Joined
- Dec 11, 2014
- Messages
- 579
The H2R Nova is Olights first 18650 battery headlamp/pocketlight with a groundbreaking 2300 ANSI rated lumens. The highly efficient CREE XHP50 LED in combination with our signature TIR bead lens delivers a perfectly balanced and even beam for maximum usable light when you need it. The H2R Nova is held in place on the head strap with a magnetic mount that wraps over the body of the light for a secure fit every time its attached. The light is easily removable from the head strap and comes with a dual sided pocket clip to use either bezel up or down to meet your needs specifically. The included custom 3000mAh 18650 battery is charged with Olights' signature magnetic USB charging cable directly through the tailcap. There is no need to remove the battery from the light allowing you to charge on the go with ease. With long runtimes coupled with extreme brightness, the H2R Nova is the perfect all around light to meet anyone's needs in the dark.
The H2R is currently up for pre-order in the USA at https://www.olightstore.com/led-flashlights/headlamps/olight-h2r-nova and international dealers soon.
Key Features:
Key Features:
- maximum output of 2,300 lumens making the H2R the brightest single 18650 battery light.
- multiple use options including an easily detachable headband turning it into a pocket light.
- Rechargeable through Olight's signature magnetic charging system
- Low battery indicator. The light will blink once per minute when the battery is running low, and continuously blink twice when it is running out.
- Slightly angled surface for the switch to locate it easily in the dark and promote more natural operation.
- Gradual brightness changes. When turned on/off on medium, high, and turbo modes, it will light up or fade gradually to protect eyes from the stimulation caused by sudden brightness changes.
- SOS mode available for emergency use.
