Olight Baton 3 question
JimAShaw
I own an Olight Baton 3 standard that use the MCC 1A cable charger that comes with it.
Yesterday, I received the new Baton 3 Dragon-Phoenix Premium which uses a case to charge.
I tried to charge the new Baton 3 Dragon using the MCC 1A charger but it does not seem to charge. Is that the way it is or is there something wrong with the Baton 3 Dragon that doesn't allow it to charge by using the MCC 1A cable?
parang
Sorry I can't offer any help. Non-standard, incompatible technology is the principal reason I stay away from Olight.
JimAShaw
If you're not able to respond to a post with help, why respond at all or, in your case, respond with a negative?
parang
I think Olight creates negativity with proprietary tech and if we let it go without raising our voice they won't stop.
Bad business practices must be called out - there is no other way to eradicate them, but to raise awareness and influence people to vote with their wallets.
Dayton, Ohio
Only negativity I see is from your posts. :confused:
Dayton, Ohio
First, do ignore the Olight negativity. Olight users have decided to leave here and went to Facebook (an evil place I don't go myself). So you will still find Olight fans here. They make top-notch lights.
The Baton 3 standard does come with the 1 amp charger, and the wireless charger in the Premium also charges an insterted light at 1 amp. So it should work. I assume the standard will charge in the wireless charger too?
