Olight S2R Baton II - Upgraded Version of S2R Baton
gearvita
The Olight S2R Baton II flashlight is the upgraded version of the popular S2R Baton predecessor. It has a compact build (5% shorter than S2R Baton) for easy grip and portability. The light can produce a maximum output of 1,150 lumens including an upgraded TIR lens that produces a perfectly balanced beam. It has several modes to choose from including three standard modes, turbo, moonlight, and strobe. The S2R Baton II features a battery indicator located on the side switch so you always know when to charge. It boasts a new MCC II magnetic charging system to ensure faster charging in a smaller form factor. The S2R II also features a dual direction pocket clip for enhanced everyday carry.
Main Parameters:
LED: Luminus SST-40 CW LED
Max Performance : 1150 lumens
Beam Intensity: 4,600cd
Max Throw: 135 meters
Power Source: Customized 3200mAh 3.6V 18650 Battery
Water Resistance: IPX-8
Impact Resistance: 1.5 meters
Output and Runtime:
Turbo: 1150~400 lumens ( 2 + 230 minutes )
High: 400 lumens ( 4 hours )
Medium: 120 lumens ( 14 hours )
Low: 15 lumens ( 100 hours )
Moonlight: 0.5 lumens ( 60 days )
Product Features:
● CW LED with a maximum output of 1,150 lumens.
● Includes a 3200mAh 18650 rechargeable lithium battery which is charged magnetically through the tailcap charging cable.
● A battery indicator located on the side switch so you know when to charge. Indicator glowing green (battery remaining ≥ 70 % ), indicator glowing yellow(battery remaining 15-70%), indicator glowing red (battery remaining ≤ 15%).
● MCC II magnetic charging system included for fast, efficient charging.
● Brand-new TIR lens design producing a perfectly balanced beam.
● Flat tail-cap with a strong magnet allowing the ability to use as a hands-free work light.
● Multi-function side switch with five brightness levels, plus a Strobe mode.
● New compact design is 5% shorter and lighter than original S2R.
● Multiple carry options with the included pouch, 2x pocket clips, and lanyard.
Olight S2R II takes the popular S2R flashlight to the next level, but there is no significant difference in price. The price on GearVita is $69.99, only a few dollars more expensive than its predecessor: https://gearvita.com/olight-s2r-baton-ii-flashlight-1150-lumens.html
You may like:
cheap xiaomi mi a2 lite smartphone
cheap xiaomi mi max 3 4g smartphone
