Random Dan
- Joined
- Jun 30, 2012
- Messages
- 1,371
Read two posts up.
I was aware of that. The website says the clip won't fit on the tail cap anymore, as mentioned above, but that it does
fit on the bezel end.
Read two posts up.
What did you use to grind it out? Can it be made to fit z clicky tsil?
Thank you. P
My apologies. I don't have an HDS handy and was going on 3rd party information. I did not verify in hand before posting that information. I've updated the universal pages to preclude any HDS compatibility. PM sent on your order.I would probably give that a try, but I do not have access to a dremel right now. I'm disappointed that it does not work as advertised without modification. This is not something I would have expected from Oveready.
Sorry for the concerns. The only fault here is ours, making a clip incompatible with such popular applications. And one we will correct if another run is warranted. You've been nothing but supportive and generous as your latest post attests. Please continue as you have, supporting the flashlight community with much needed information.If I had some part in causing issues with customers then I whole-heartedly apologize to them.
Speaking of helping -- Random Dan, if you want to send me your clip I'll mod it to work on your light. No charge. I don't want anyone to feel like I've caused a problem here, so let me fix it whether it was really my fault or not.
Comin late, when universal clips will be available in clip store again?
