Sold/Expired P60 modules - warm, neutral, cool white/XPG-S2- XML-U2 / P60 modules (part 9)
Status
Not open for further replies.
nailbender
North Carolina
PART 9 !!! P60 Style Custom Drop - in modules for SF and other Products. (part 8 can be found here)
Here I am offering P60 Style drop ins, they are available with Leds from the following manufacturers with some of the leds that will be offered are below.
SSC Seoul - P7 , P4
Cree -
XML , XPG, XP-E, MC-E, XRE , UV, are here in warm , neutral or cool white
Osram - Diamond Dragon , Golden Dragon Plus, PDP IR/ Ostar IR
Luminus - SST -50, SST -90
Rebel
These modules will fit most flashlights that accepts a standard P60/D26 Style module.
THESE DO NOT FIT OLD STYLE G2 HOSTS
IF a GREAT host is needed here are some great hosts by Five Mega to look at (HERE)
Here is one of the emitter in the base and converter board
View of the module from the top and typical beam shot
You can still see a bit of a doughnut hole in this picture but most of the time we can focus all or most of it out.
This is a picture of the reflector made for the Cree XPE XPG This gives a very smooth and concentrated hotspot.
New OPTICS Modules for XRE only
All of the modules end up being as close to standard length as possible The large die leds are much thicker and there is a small possibility that there will be a crack at the head and body. I keep all as short as possible so if there is a crack there is probably nothing that can be done.
All hosts are slightly different and one module may fit tight in a SF product and a bit loose in a FM Nite clone or an FM C but they will fit all. One may need to have the spring cut down to allow the head to close or a whole spring may be needed to keep the module from rattling. They also fit most Solarforce or any P60 style host
Most LED's are carried in Cool White, Neutral White, or Warm white when possible. They will be listed if in stock if not listed probably not in stock.
Battery configs listed are for any battery that falls into the range listed.
Potting option is the filling of electronics cavity with thermal epoxy for heat management and shock protection. Copper tape is included with potting option and any module can be potted. Option is $5
EMITTERS CARRIED
Seoul P7 $65 - 3.6v - 6volts ONLY /
1- 3 or 5 levels direct drive or 3 level regulated /Cool White
__________________________________________________ _______________________
CREE LEDS
http://www.cree.com/products/xlamp.asp binning and tint informaiton (GREAT RESOURCE)
Cree XM-L $40
U2 flux bin 1C 6500k+ Cool White
T60 flux bin 3C 5000k daylight white
T50 flux Bin 4C 4300K neutral white
T40 flux bin 5B3 4000k neutral white
T40 flux bin 6A3 3500k Warm white
T30 flux bin E7 3000K Warm White
Direct drive
1 Level only (potting and tape included this model only)
works well in the 26650 Cooly's by Five Mega.
3 level / 2.8 amp /3.4 - 9 volts (high / med / low with memory ) NEW!!! $45 Best used with 2X Li ion or 2X primaries
Available levels with memory (2.8-6 volts only)
1 level Regulated
2 level HI / Low Regulated
3 level Low / Med / High Regulated
3 level Hi / Low / Strobe Regulated (rotation of levels may change between driver batches)
5 level Low / Med / High / SOS / Strobe Regulated
6 volt Drivers can be pushed at 3.1 amps and
3.5 amps or even 4.2 amps but high should be used for shorter periods these do work well in the 26650 Cooly's by Five Mega.
and in
2P 18650 P60 M*g 1D by Fivemega There is no extra charge for these.
If you want to use continuously on high in most hosts please use 2.8 amps for better heat control and you will also get much better runtime.
Either Smooth OR Op reflectors available (extra reflectors not available at this time.)
Potting with copper tape is a $5
XML TOWER MODULES $80 NEW!!!!
T6 flux 1A tint *ONLY EMITTER AVAILABLE AT THIS TIME*
Any of the above 6 volt max drivers listed under XML's plus ones listed below
1 level 4-16 volt 2.2 amp driver
3 level 3.4-9 volt 2.8 amp driver
Fits any of the surefire turbo heads such as KT1 / KT4 / KT5
Cree
XP-G -$35
2.8-3.6 (levels are 100% / 40% / 5
% ) *mixture of throw and flood*
5 level high / med / low / SOS / Strobe with memory / 1.4 amp / 1/7 amp
3 level high / med / low 2.8-6 volts with memory / 1.4 amp / 1.7 amp
1 level 2.8-6 volts
1 Level 4-14 volts / 1.5 amp
3 levels high / med/ low / 3.6-9 volts no memory / 1.4 amp
5 level 1v-4.2 volts for low voltage for A / AA lights NO L2R HOSTS they are not compatible with my low voltage drivers
Flux Bins and tints that are available for XPG
Q23000K 7A3 (90 minimum CRI) NEW
Q3 3000 7C1 (85 minimum CRI)
Q4 2900k 8A4 tint
Q5 3000k 7A3 , 7B4 tint
R3 4000k 5C2
R4 4000k 5B3 tint /5B2
R4 5000k 3C tint
R5 5500k
- 2T tints (Cool White comparable to WH tint)
S2 6300k - 1T tints (coolwhite comparable to WF tint)
DUAL XPG (Linger Special)$45 Any of the above bins are possible / 3 level 2.8 amp 3.6-6 volts max *Floody* (levels available are same as XML)
DBS MODULES AVAILABLE ON REQUEST for most emitters / brass pill only no reflector/ same price as regular modules, potting is available on these also.
CREE XPC $30 (new)
Q5 WC tint available in 1 / 3 levels with memory in 1.4 or 1.7 amp
Cree XRE - XPE -$30 -
2.8 - 6 volts 3 level regulated high / med / low
3.6 -8.4V regulated 3 levels high / med/ low (memory ?)
XPE
R2 or R3
available coolwhite / (Q3 5B)
neutral /warm tints
XPE Green , Red, Amber /Blue
XRE (Good Throw )
R2 flux WF tint
Q45B neutral
8E7 warm white
Green and Blue colors
Smooth OR OP reflectors are available
Optics are for XRE emitters only
/ Cool white , neutral white and warm whites.
8degree/ 60 degree.
$37 for module and 1 optic $40 with 2 optics
__________________________________________________ _________________________
Cree MCE $ 55 - GOOD FLOOD
1 - 3 or 5 level regulated
3.6 - 6 volts
Cool - M bin WD, WG
Cool - Nbin no tint supplied but pure white
Neutral - Kbin 5B tint
Warm bins JE5, JE6, KA3
OSRAM LEDS
Osram Diamond Dragon $40 - 3.6 -6 volts / 1/ 3/5 level
Ultra White /WARM WHITE/True Green / Red
Osram Golden Dragon Plus $40 -3.6 - 6 volts Regulated high / med / low /
3.6 - 8.4v 3 level High / Med / Low
Ultra White, , Warm White tints
Platinum Dragon - Hyper-Red this is a true red no orange red. $40
__________________________________________________ ___________________________
LUMINUS SST SERIES LEDS
Luminus SST-50 - $55 -
2.8 -6volts only *good throw with adequate spill*
direct drive
1 Level direct drive
Regulated with memory offered with same amperages as XML's listed above
1 level
2 level --High - low
3 level -- high - med - low
3 level -- high - low - strobe
5 level -- high - med - low - strobe -SOS
Driver Levels are 100% / 40% / 5%
Flux Bins are
6500K Cool White
(W65S-GJ102-WJ-G4 )
5700k (w57S-GJ201-WJ-H4 )
4500k (w45S-GJ400-WJ-P3 )
DBS MODULES AVAILABLE ON REQUEST *pill only*
Luminus SST -90 -$70 -
2.8 -6 volts only *Floody*
1 Levels direct drive
Also available in regulated drivers with memory of the same amperage drivers used with XML's above
6500 (W65S-WN-G3 )
5700k (W57S-WN-H4)
3000k warm 83CRI ( W30M-GK700-WK-U3 )
Green - Red
- Blue Colered SST90's also available
UV LEDS
Cree UV XL 7090 $45 (395nm)3.6 v-6volts /1 level I ALSO CARRY A BLOOD TRACKING PACKAGE THAT IS AVAILABLE WITH SPRAY BOTTLE FOR HUNTERS , PLEASE PM FOR DETAILS.
OSRAM IR LEDS
Osram Platinum Dragon IR $45 (850 940nm)-3.6v- 6 volts /1 level 2.8-6 volts
Quad Die 10watt IR great for night pictures
I also have
Rebels CW / Neut/ warm high CRI/ Royale Blue
K2TFFC CW / Neut/ warm
Seoul P4 - CW / Neut / warm 90 CRI
please PM for info on these
modules
I try to keep the above listed led's in stock, I also try to keep the newest and most popular bins and color temps from cool whites / neutrals / and warm white high CRI models.
Now as to levels in drivers , most of the time the levels are fixed and can't be changed. As new drivers become available the offerings will change on this page so please check it first. I often will have to change depending on what drivers I have available to me at the time so please check this page and I will update as needed.
Please specify what host and batts you are using when inquiring about a module or led. Just remember if you don't see it or don't understand something just write as I don't mind helping but check this page first. These are not try and buy!
Now that said the search button for the forum has a wealth of knowledge, much more than I can ever remember and usually with in days of a new led release runtimes and lumens are often posted please check the forum's search box as it is invaluble.
When ordering please post your order in this thread plus put details in Paypal notes of what emitter and tint ordered/ include choice of reflector / # of levels / check to see if shipping address is visible . Also please list CPF Nickname in paypal notes.
Shipping is 3 working days Shipping confirmations are sent when mailed
Make sure your address in paypal is correct becuase that IS WHERE IT WILL BE SENT.
If you want it mailed to an alternate address
from the paypal address please state I want my parcel sent to an alternate address if this is not done I will think it is a duplicate address and will send to what is listed on PP.
MY Paypal info in biography or PM for it / I do not send confirmations that I received your paypal if properly addressed then I WILL receive it, you should be receiving a receipt from paypal when sent.
Credit card users please add 4%
Shipping Conus is included 1st class, Priority is $5 for up to 3 modules / International shipping is $5 for 1st class Int up to two modules , Priority Mail Int. is $15 up to 3 modules , express mail and more than 3 modules quoted.
Beam shots are posted below and new products will be posted below. Please send your beam shots and I will try to list when possible or create a link to them.
New offerings will be listed below as they become
available.
D36 for M STYLE and M to C lights are (HERE)
IN NEED OF A HOST THEN HERE ARE SOME GREAT FORUM MEMBERS THAT CAN HELP
Here on BST get Five Mega hosts (Here) These are some of my favorites and the new coolys
On marketplace get Fivemega 18mm Bodies in 5 Sizes Here
Jason will take care of you.
For milling of maglites and general millwork Will Quiles is the master and can be found (HERE)
nailbender
North Carolina
Re: P60 modules - warm, neutral, cool white/XPG- XML / SST-50 -90 P60 modules (part 9
Announcements and new offerings
Hi All
this will be where I post new emitters or offerings plus any news on the module front. A few links may not work in the new part of the thread but I will work on that in the next couple of days.
I now have S2 XPG's in 1T tints and for those of you that don't keep up with the flux bins the S2 is the next step up from R5 flux, the 1T tint is one of my favs and I am sure you will like. The XPG is great for a EDC light where you want plenty of light with a good balance of throw and spill yet you still can get decent battery time. You will get about TWICE the runtime as a XML
I have also acquired some T6 XML's in 3C, I had been only able to get these in T5 flux so the 5000k XML's which are basically a daylight white are now available in the same flux bin as coolwhite.
I am always watching the suppliers for the newest flux bins best tints so check back for new offerings.
10/24/2011
For the members that want to use 2X18650's, as you know I don't have high amperage drivers that will work with 8.4 volts but I have been using my 2X18650 D36 five mega host with 2X18650 LifePo4 batts. This system has been giving me good results, now the mah are much less than li ion but I have been getting good runtime as I use mostly 10 minutes at a time taking the dogs out. You can purchase Lifepo4 18650's in numerous places from DX to batteryspace where I got mine. PLEASE remember that LifePo4 needs to be charged at 3.2 volts NOT 3.6, many ultrafire chargers have dual settings on the side. Just a option for multi celll users.
11/4/2011
The postman brought a surprise today, the long awaited XML-U2's are here in 1A tint
11/20/2011
I now carry 26650 MNKE IMR cells for those of you looking for cells for the newCooly's I also carry 18650's PM me for details. I also have chargers for these 2 items.
I will also one day this week will finally have 2.8 amp 3 level drivers for 3.4-9 volts. This means yes I can make modules with XML's that you can use in your 2X 18650's or any 2X Li Ion set up or any 3X CR123 primaries. I am not sure what day they will be here but probably tomorrow or Tuesday. They were in customs in NY yesterday so pretty soon!
I will post here again when they arrive
Dave
11/21/2011
Hi All
The new 3.4 -9 volt / 2.8 amp / 3 level with memory drivers have arrived so we now have a solution for any 2X li Ion or 3X CR123 primaries configuration.
Dave
12/21/2011
Hi All
First off I want to wish all a safe and happy holiday season. I also want to wish a safe and prosperous NEW YEAR.
OK now to modules.
I am now stocking a few XPC's that some members have requested. i at this time only have Coolwhite. They are Q5 WC tint. Q5 is the highest flux bin made at this time. They will be available in smooth or OP. While there are some rings I have a new smooth reflector made for XPG / XPE / XPC and they really not to bad. They do have a good dedicated hotspot. They will be available in 1 / 3 / 5 levels and in 1.4 or 1.7 amps. I have been able to push these to 1.7 amps with out any bluing of the beam. Price is $30
Instead of posting a new thread right away I thought I would post here in this thread that I have some XML tower modules for KT1 / KT4 / KT5 surefire turbo heads. I wanted to make them available to all of you that have followed my thread through the year. I have them listed under the XML's above along with the drivers. They are only available in T6 flux and 1A tint for now as that is how I have bought the emitter on boards and they are not easily changed. I have been able to keep the beam quite tight like my XPG's have been. I don't know of any towers being made with XML's.
Thanks and have a great holdiay season!!!!
Dave
nailbender
North Carolina
Beam shots
Give me a few days and I will try to recover some of the beam shots that were lost with the forum crash. Any members who want to post beam shots just PM me and I will post here.
badtziscool
I'll take one of these:
Cree XM-L $40
2.8-6 volts
T6 bin 3C
3.1 amps
Op reflector
:paypal:
bugsy714
What would the otf lumens be for the above mentioned dropin? Glad things are getting back to normal again!
nailbender
North Carolina
Hi
I am guessing you mean the T6 3C bin that badtziscool ordered, it should be around 650 lumens + or- a few lumens
Dave
Ray1968
Simi Valley, CA.
Dave,
I have one of your cool white MC-E drop ins from 2009. As far as lumen output, how would the current XM-L T6 1C / 1D compare to the older MC-E?
konig
Sweden
Cree XM-L
T50 flux Bin 4A 4500K neutral white
1 level 2.8A
Op reflector
Potted
40+5+5(int. shipping)+4%=52$
Will be using the P60 in a SureFire C2 with 18650 battery.
nailbender
North Carolina
Dave,
Hi
I would imagine the MCE was direct drive so it will depend on battery condition, if regulated the MCE will be between 50 and 100 lumens dimmer than the XML. i don't know if it was a M bin or a N bin but probably a M bin and I think I labeled most of those at 550 lumen. The biggest difference is the XML's will have much better throw while still having adequate spill.
Dave
fongskiz
Singapore
Hi Dave, :paypal:
Thanks for the PM advise. PayPal sent for 2pc of P60 module for use in AW17670 battery. Attached Unique Transaction ID. #80B61315EC7499913.
Module 1
- Cree XM-L T50 flux Bin E4 4500K neutral white
- 2.8 amps
- OP reflector $40
- Potting with tape $5
Module 2
- Cree XM-L T6 bin 1C / 1D Cool White
- 3 level Low / Med / High
- 2.8 amps
- Smooth reflectors $40
Stephen
Chrisdm
Paypal coming for:
XM-L drop-in
T50 4500k
2.8a regulated 2 mode (hi-low)
OP reflector
yellow
Baden.at
Great offers.
Finally thinking of giving the XM-L a try.
a few questions:
* the daylight XM-L, shouldn't that be "3C" instead of "6C" - I am somehow not able to find 6C
* the XP-G mentionned in post #2 - will there be a driver low-med-high (+ memory) available?
* what does
mean here?
[edit]
1st question answered by post #2,
potting question answered by post #1
[/edit]:rolleyes:
fockus
Hi Dave,
Is 1.4 amp the highest you have available for XRE R2? It'd be used in a SolarForce L2-series with AW protected 18650 2900mah.
nailbender
North Carolina
Great offers.
a few questions:
* what does mean here?
[edit]
[/edit]:rolleyes:
Hi
As listed in first post
I have changed the 6C to 3C as it was simply a typo when rewriting for section 9
There is memory for the 6 volts only, the no memory pertains to the 9 volt version and I will not be reordering for awhile so not at this time. I have a 1.2 amp version (the other is 1.5 amp) that is 9 volt max which 3 levels that has memory.
Dave
nailbender
North Carolina
Hi Dave,
Hi
1.4 amps is as high as I like to push a XRE, at 1.4 amps it is 40% higher amperage than the manufacturer suggests. Once you go by 1.4 amps the emitter starts to color shift which usually means trouble is a brewing.
Dave
RCantor
KC, MO
What are the neutral XRE alternatives and can I get an 8 degree optic and a smooth reflector so I can switch back & forth to see which I like better? How much would getting both be? Thanks.
BIGLOU
Dave, Hello. I was wondering if there is a big difference or the difference in the T5 5000k tint rated at 600 lumens and the new offering T60 flux bin 3C 5000k daylight white. Thanks. I'm a big NB XML junkie and was thinking if I should get this one.
nailbender
North Carolina
Hi
I have Q45B for neutrals.
Sorry the way the modules have to be built for the optics holder it is impossible to switch between optics and reflector.
Dave
nailbender
North Carolina
Hi
There is around 40 lumens difference not a whole lot. It puts them on equal par with the coolwhites.
Dave
BIGLOU
Thanks for the quick reply Dave!
Status
