Sold/Expired P60 modules -warm, neutral, cool white/XRE-XPE-XPG-XML-U3 / NICHIA 92CRI PART 11
Theocrat
Dave, could you clarify the price of the Olson Black IR module shipped within the continental US in this configuration and I will paypal you the payment in a few days.
P60 Black Oslon 850nm IR,
2.8-6v,
1 level
OP reflector, do not threadlock please
potting
its going in an Ultrafire 502b
Thank you.
nailbender
North Carolina
2.8-6v,
1 level
potting
Thank you.
Hi
$45 shipped
Dave
6010 nsk
Western Co
Hi, I am wanting to build as big of thrower with a green led out of a sure fire 952. I ordered a streamlight super tac head for my reflector I have a SF P60L and G&B led drop in. What green led and battery combo do you suggest? I would like to use rechargeables. Long runtime not required. Thanks for any help. -A
nailbender
North Carolina
HI
I am a bit lost at what you want from me here, a 952 to my best recollection takes a D36 style module since most use a M3 style head. You also mention a streamlight that I did not know took a P60 style module in any model.
Are you just looking for a pill and you will be trying to match together. Not quite sure what you are after here.
Dave
6010 nsk
Western Co
Sorry I was not clear. My 952? uses p60 type pills. I think it has an m2 head.
I bought the streamlight head to adapt to it for throw since I played with one and was impressed with the throw. I want to make it green for hunting.
I was thinking i could mod one of the pills I have or if it is cheap enough to have you build me one then make the adapter for the streamlight head.
Clear as mud ? :)
Well I just went to your site and found a green one. What output can I expect from it ?
nailbender
North Carolina
Clear as mud ? :)
Hi
Well mud has nothing to do with it. If your 952 takes a M2 head then a standard P60 module with reflector is what it will take providing you are using the shock material with it.
Now as for the streamlight as long as you can make it work is great with me but to my knowledge a P60 pill will not work as is with a streamlight lamphead. Now since I don't work with them since they don't use P60 modules I have not studied them as you must have.
I have a green XPE and a green XRE, both are quite bright. Since my calibrated sphere doesn't work with colored emitters I can not give a lumen count but the XRE will have the most throw. Both are quite bright but the XRE is about 90 degree's in beam width while the XPE is about 115 degrees.
Dave
leadsled9
Dave, I'd like one drop in with the following specs:
PayPal Transaction ID: 9K79207618519091M
LED = XML U3 flux bin 1C 6500k+ Cool White
driver = 2.8-6 volt regulated; 1 mode; 2.7 amps max.
reflector = Smooth
Total $40
Will be run in bored Surefire C2's with 1X18650 or 2XCR123A primaries
SoSideways
Oh snap! Cree just added the XM-L2 to their site! How soon do you think you'll be offering XM-L2 modules Nailbender Dave?
thejrod
Good place to ask I hope...
I (well my wife for xmas) just ordered the P60 XML U3, 2.8-6v direct from your website. Any idea of brightness and runtime from 2 CR123s?
Thx.
nailbender
North Carolina
Thx.
Hi
Be careful running any module at 3 amps on CR123's, while some are rated that high many primaries are only rated to 2.5 amps. I have never had problems but I always want folks to be safe, many newer primaries have PTC fuses rated at up to 5 amps but not all primaries are this advanced.
I do not keep runtimes as there are WAY too many variables for me to do runtimes. A good way to do an estamated runtime is to take the mah of the battery and divide by the amperage. So it would be 3 amps divided into 1400 mah for most primaries or about 25 minutes or so on high.
Dave
thejrod
Awesome, thanks. What do you recommend as the best battery set up in a solar force l2t with that module? Sounds like the panasonics in a 18650 is the best bet...
6010 nsk
Western Co
Hi
Dave
Thanks for the info. I am going to try and thread the outside of the M2 head and remove the lens to take the streamlight head/reflector. Ill buy an XRE. Thanks. - A
nailbender
North Carolina
Hi
Any 18650 is a good choice. I still think you get the best efficiency and of course runtime.
Thanks
Dave
gswitter
California
Dave,
What is the order (and amperage) of the levels of your 3 level .8v-3 volts (XP-G/Nichia) driver? And does it have level memory?
(Sorry if you answered this previously, but my less-than-thorough search didn't find it.)
RCantor
KC, MO
So, Dave :) When are you getting these? If you get some in 4500K I'll get one :)
Cree has announced what it says is the brightest single-die packaged LED on the market that maxes out at 1198 lm at 3A of drive current, and that can deliver 186 lm/W efficacy at a lower drive current.
I'd also love a Mag triple. /drool.
T45
Wichita KS
Dave
Just looked on your sight and saw your P60 drop in for a 2xAA configuration and was curious if you could make a module for that same configuration, but in single mode and around 150 to 175 Lumens? I would like an OP reflector as well. I would be using it in a Surefire 9P as a host with a M2 head. I know about the Malkoff M31 series and the Solar Force Cree XPG Dropin 1 Mode .8-4.2V. Looking for something in a mid range output, 300 Lumens is more than I want as runtime has more priority for me.
nailbender
North Carolina
Dave
Hi
I can make you a single mode but boost drivers are harder to manipulate their amperage. So yes I can get you a one mode but I really can't drop the amperage.
Dave
