Sold/Expired P60 XPG modules - warm, neutral, cool white/SST-50 -90 P60 modules (part 7)
nailbender
North Carolina
PART 7 !!! P60 Style Custom Drop - in modules for SF and other Products. (part 6 can be found here)
Here I am offering P60 Style drop ins, they are available with Leds from the following manufacturers with some of the leds that will be offered are below.
SSC Seoul
- P7 , P4
Cree - MC-E , XP-E, XRE , UV THE NEW XPG are here in warm , neutral or cool white
Osram - Diamond Dragon , Golden Dragon Plus, GDP IR/ Ostar IR
Luminus - SST -50, SST -90
Nichia - UV
K2 TFFC
Rebel
Ledengine- UV
Please refer only to part 7 for prices and current selections.
These modules will fit any flashlight that accepts a standard P60/D26 Style module.
IF a GREAT host is needed here are some great hosts by Five Mega to look at (HERE)
Here is one of the emitter in the base and converter board
View of the module from the top and typical beam shot
You can still see a bit of a doughnut hole in this picture but most of the time we can focus all or most of it out.
This is a picture of the new reflector made for the Cree XPE & XPG This gives a very smooth and concentrated hotspot.
New OPTICS Modules for XRE
All of the modules end up being as close to standard length as possible The large die leds are much thicker and there is a small possibilty that there will be a crack at the head and body. I keep all as short as possible so if there is a crack there is probably nothing that can be done.
All hosts are slightly different and one module may fit tight in a SF product and a bit loose in a FM Nite clone or an FM C but they will fit all. One may have to have the spring cut down to allow the head to close more or a whole spring may be needed to keep the module from rattling.
Here are some of the modules that can be purchased with some of the configurations.
Most LED's are carried in Cool White, Neutral White, or Warm white. They will be listed if in stock.
Battery configs listed are for any battery that falls into the range listed.
ALL LEDS BELOW ARE STOCKED
Seoul P7 $65 - 3.6v - 6volts ONLY /
1- 3 or 5 levels direct drive or 3 level regulated /Cool White
CREE LEDS
Cree XRE - XPE -$30
- 3.6 - 6 volts 3 level regulated high / med / low
3.6 -8.4V regulated 3 levels high / med/ low (memory ?)
XPE R2 or R3 available coolwhite / neutral (Q3 5B) and warm tints plus new XPE Green , Red
XRE OPTICS Cool white , neutral white and warm whites.
8degree/ 60 degree.
$37 for module and 1 optic $40 with 2 optics
Smooth and OP reflectors also available
Cree
XP-G -$35 (levels are 100% / 40% / 5% )
5 level high / med / low / SOS / Strobe with memory / 1.4 amp
3 level high / med / low 2.8-6 volts with memory / 1.4 amp
2 levels High / Low 2.8-6 volts with memory/ 1.4 amp
1 level 2.8-6 volts or 4-14 volts / 1.4 amp
3 levels high / med/ low / 3.6-8.4 volts no memory / 1.5 amp
3 & 5 level 1v-4.2 volts for low voltage for A / AA lights NO L2R HOSTS they are not compatible with my low voltage drivers
Flux Bins and tints that are available for XPG
Q5 3000k 7D2 tint
R4 4000k 5B3 tint /5B2
R4 5000k 3C tint
R5 6500k 1C
/ 1B / 1A tints
DUAL XPG (Linger Special)$45 Any of the above bins are possible / 3 level 2.5 amp 3.6-6 volts max
DBS MODULES AVAILABLE ON REQUEST
Thermal Potting available upon request $5 upcharge. 1 mode 2.8 amp drivers are $5 upcharge because of cost of drivers.
Copper tape now included in price the price to pot a module with thermal epoxy.
Cree MCE $ 65 - 3.6 - 6 volts/
1 - 3 levels or 5 levels direct drive
1 - 3 level regulated / Cool - Neutral - Warm bins
OSRAM LEDS
Osram Diamond Dragon $40 - 3.6 -6 volts / 1or 3 level
Ultra White /WARM WHITE/True Green / Red
Osram Golden Dragon Plus $40 -3.6 - 6 volts Regulated high / med / low /
3.6 - 8.4v 3 level High / Low / Strobe
Ultra White, , Warm White tints
LUMINUS SST SERIES LEDS
Luminus SST-50 - $65 - 2.8 -6volts only
direct drive
1 - 3 or 5 levels only
100% / 45% / 10% (add SOS and Strobe for 5 level)
Regulated
1 level
2 level --High - low
3 level -- high - med - low
5 level -- high - med - low - strobe -SOS The driver is the Shiningbeam driver 2.8 amps
Driver Levels are 100% / 40% / 5%
Flux Bins are
6500K Cool White
(W65S-GJ102-WJ-G3 )
5700K neutral (W57-GJ201-WJ-H4 )
4500K neutrals (W45S-GH400-WJ-N4)
Luminus SST -90 -$80 - 2.8 -6 volts only /1 - 3 or 5 Levels direct drive
6500K Cool White (W65S-GN100-WN-DE) (Out of Stock no estimate)
5700K neutral (W57S-GN200-WN-H4)
good replacement for coolwhite
4500k neutral (W45S GM401-WM-P4)
3000k warm 83CRI ( W30M-GK700-WK-U3 )
Green - Red
- Blue SST -90's also available - $80
UV LEDS
Cree UV XL 7090 $45 (395nm)3.6 v-6volts /1 level
Nichia UV $125
(365nm)3.6-6 volts 1 level (Temp. Out of Stock)
I ALSO CARRY A BLOOD TRACKING PACKAGE THAT IS AVAILABLE WITH SPRAY BOTTLE FOR HUNTERS , PLEASE PM FOR DETAILS.
OSRAM IR LEDS
Osram Golden Dragon IR $45 (850 & 940nm)-3.6v- 6 volts /1 level or 1 level 4-14 volts
Osram Ostar 21 watt IR (850nm & 940nm) 9-16 volts 1 level
I also have
Rebels CW / Neut/ warm high CRI/ Royale Blue
K2TFFC CW / Neut/ warm
P4 CW / Neut / warm high CRI
please PM for info on these
ANY MODULES LISTED AS 6 VOLTS MAX CAN NOT BE USED WITH LIFEPO4 BATTS. THERE HAS BEEN TOO MANY PROBLEMS WITH THESE BATTS AND PROPER CHARGING METHODS. WARRANTY WILL NOT COVER BOARDS BURNED UP BY USING THESE BATTS.
I try to keep the above listed led's in stock, I also try to keep the newest and most popular bins and color temps from cool whites / neutrals / and warm white high CRI models.
Now as to level in drivers , most of the time the levels are fixed and can't be changed. Now that said some drivers may have groups so that I may be able to accommodate some changes not shown such as special strobe packages for bike riders and such.
As new drivers become available the offerings will change on this page so please check it first. I often will have to change depending on what drivers I have available to me at the time so please check this page and I will update as needed.
Please specify what host and batts you are using when inquiring about a module or led.
Just remember if you don't see it or don't understand something just write as I don't mind helping but check this page first.
Now that said the search button for the forum has a wealth of knowledge, much more than I can ever remember and usually with in days of a new led release runtimes and lumens are often posted.
When ordering please post your order in this thread plus put details of what typed led ordered including choice of reflector / levels and type driver DD or regulated / check to see if address is visible . Also please list CPF Nickname in paypal notes. Shipping is 3 working days
Make sure your address in paypal is correct becuase that IS WHERE IT WILL BE SENT.
If you want it mailed to an alternate address Please make sure I acknowledge that the paypal address is incorrect.
Do not send me an alternate address with out making it known the paypal address is incorrect, please state I want my parcel sent to an alternate address if this is not done I will think it is a duplicate address and will send to what is listed on PP.
MY Paypal info in biography or PM for.
Credit card users please add 4%
Shipping Conus is included / International shipping is $5 for 1st class Int up to two modules , Priority Mail with tracking is $15 up to 3 modules , express mail and more than 3 modules quoted.
Beam shots are posted below and new products will be posted below. Please send your beam shots and I will try to list when possible or create a link to them.
I will as I can try to keep wall shots updated as for outside beam shots those will probably be left for others as my camera doesn't take good shots out side at night or could be the operator is not good enough:D
New offerings will be listed below as they become
available.
D36 for M STYLE and M to C lights are (HERE)
IN NEED OF A HOST THEN HERE ARE SOME GREAT FORUM MEMBERS THAT CAN HELP
Here on BST get Five Mega 1 & 2 X 26500 host (Here) These are some of my favorites
On marketplace get Fivemega 18mm Bodies in 5 Sizes Here
Jason will take care of you.
For milling of maglites and general millwork Will Quiles is the master and can be found (HERE)
nailbender
North Carolina
beamshots
SST-50 on left and SST -90 on the right
Warm MCE on Left & Mbin Cool White on Right.
XPE Beam shot / XPE R2 VS Diamond Dragon
XRE R2 VS K2 TFFC Warm / P7 VS XPE R2
P7 beam shot / MCE warm
Red Diamond Dragon on left / Green Diamond Dragon on right
Green SST 90
XPG R4 looks great with very smooth beam in these reflectors
nailbender
North Carolina
new items
Linger Special, this is a module that was conceived through member Linger. Out north of the border friend asked me to put 2 XP-G leds on a 10mm board side by side. So I was somewhat worried about heat and the small board and becuase of design of the board and extra mass I went with a 14mm board.
These are mounted side by side on one board and they work perfectly.
They produce 510 lumens out the front of floody yet very bright light. There is a small doughnut hole in the beam pattern on the wall but little if any is noticed outside.
This has become my wifes new light of choice. As she says I want the bright one.
Wild looking are they not.
Price will be $45 and will be using a 2.5 amps 3 level driver which pushes them pretty hard.
Dave
_________________________________________________________________
New Low Power Special I now have a good boost driver that will work with several of the leds and with voltages from 1.2v to 4.2v. These will push a XPG at 1 amps on a AA battery.
So anyone who has a single AA cell light I have a good driver for it. These also will be great with one primary for pocket rockets.
More on this one later.
OPTICS FOR DROP INS
Here is another new product. This is a way to use optics in a Drop in module. This was a few months back shown by another member and he told me that he did not mind if I had these milled.
I have to thread lock the holder so that the right distance from the led is stable so switching from a reflector to this is not recommended.
These are made for XRE and work great with them I have 8Degree narrow and 40 degree and a few 60 degree.
The pictures
The optic snaps lightly on the XRE frame and is held in by the glass in the lamp head.
nailbender
North Carolina
lamp heads
These are some Chinese cloned Lamp Holders they fit all C & P Surefire models and most clones I would imagine. I bought some to fill some FM C hosts & FM Nite hosts I had that needed heads, I bought a couple of each while I was getting some.
The quality is quite good I thought. There may be a speck of anno missing where the aggressive flutes and ribs are but very little as you can see by the pictures.
The ribs and flutes should help cool the heads some.
Any bezels you have for your C or P surefire or clones will fit these just like they do any SF product.
Here are pictures, hopefully most detail can be seen since they are black it is harder to show.
Left side I call bottom ribbed and hex shape. Right side is bottom ribbed & fluted
Left side I call top ribbed & fluted (out of stock ) is my favorite although may be to aggressive for some. Right side is top view as top is same on all
Here they are on a FM C style host and a 18650 FM Nite host
Prices are the same for any of the three.
Price of heads are $ 30 shipping included CONUS
ever4ever
Hi Dave,
congrats on part 7!
I really like the XP-G you made me, its my new EDC light. The spill/throw combo is perfect for everyday use.
In fact, I like it so much I want another module :p but for a different purpose- Thrower! :candle:.
Is it possible to get an XR-E R2 cool white with a SMO reflector, 1 level regulated on 1.2 amps draw?
Hoping to be the first buyer on this 1 :grin2:.
Thanks.
nailbender
North Carolina
Hi Dave,
congrats on part 7!
Thanks.
Hi
Sure that is not a problem, I sent one out yesterday built just like that.
Do realize that while you will have a nice tight hot spot there will be a few cree rings if you are a white wall hunter.
No doughnut hole just the old cree rings that are not seen outside.
Price as listed $30
Thanks
Dave
PS They really have a hotspot in a D36 smooth.
lemlux
San Diego
Hi, Dave:
I've received both XP-G 1.2-3V modules and my Linger special.
The Linger Special is as you and others have indicated: the flood is useful and very bright and the messy center of the hotspot is not an issue in the outside world.
I was pleasantly surprised to notice no visually perceptible brightness difference between one of the low voltage modules driven by 1@ cr123 in my P3 and the other driven by a single 1.7V NiZn AA cell in my McGizmo 17500 e-body with e<c adapter.
I'm also pleased with my choice of 5000K on these lights and with the 6500K of the tower module received earlier. The 6500K reaches out well on the turbohead thrower and the 5000K works well in the range of these D26 modules. I like the 5000K color temperature better than I do the 4000K color temperature I chose on my recently received KuKu e2 drop-in.
I'm pleased with all 4 modules I've received thus far. I'm eagerly anticipating receiving your KL4 XP-G and 5A Mag D SST-50 mods.
FWIW, as floody as the Linger Special is, the spill is only 60% the diameter of the corona of the e2 drop-in given the properties of the stock e2 head reflector.
Also, as an e2 drop-in comparison, your single D26 XP-G drop in has a familiar hotspot with graduated corona that has the same spread as the e2 drop-in while almost the entire corona of the e2 drop-in is the diffuse and uniform hotspot. These are totally different beams.
recDNA
Any plans to build P60's using the new EZ900 XR-E R2 driven hard 1.3-1.4 amps?
CLEAR
Nailbender, I'm new here and i can't send message directly to you. Can you PM me, I would like to order D26 and D36 LEDs. Thanks
nailbender
North Carolina
Hi
So that means you know where they can be purchased for sure? Cutters is not a sure bet, Arrow is not a sure bet, digikey doesn't stock them nor does Newark so what is your secret.:D
Dave
recDNA
Hi
Dave
Sorry, no. I read about them and thought they were available.
If they do become available sounds like they'd be good for throw though.
Kid9P
NJ
Hey Dave,
I'm looking for something in your 1v-4.2 volts for low voltage category.
Just got a light that will be running on a single 18500 cell.
3 mode would be great. Is my only option the Cree XP-G R5 -$35 ?
Thanks!
Ray
red02
Hey Dave,
Thanks!
Ray
You'll probably kill a Li-Ion if you run it down to 1v. Protection circuits are nice, but don't always work.
Kid9P
NJ
I charge my cells way too often, it will never get down to 1v :D
nailbender
North Carolina
Hi
If somehow I find a few I will consider it, but I run my EZ1000 at about 1.3 amps right now, both are 90 degree viewing angle so except for the recent fervor over them the difference in a sphere is minimal at best.
Hey Dave,
Thanks!
Ray
HI Ray
IMHO I would not use a boost driver, you have 4.2 volts and unless you are going to run the batts beneath what is supposed to be I don't see a need. I would just use a 3 level 1.4 amp driver.
As for you only choice being a R5, I don't quite understand, you can use any of the XPG, XPE , XRE. Any meaning any tint.
I can make a rebel up if that is what you wanted. Price for a XPG is $35
thanks
Dave
ever4ever
Allrighty then, I'm ready to order:
I'll have an XR-E R2 -
at 1.3 amps draw regulated,
with a smooth reflector,
single mode on cool white tint.
+ thermal potting.
+ international shipping.
total: 40usd.
host is a 6p with cr123 primaries.
as soon as you tell me its all right payment will be on its way.
Thanks!
