Sold/Expired "Perfect Tri/Quad Sinks" and little ol "Minetrois"
modamag
Bay Area, CA
\"Perfect Tri/Quad Sinks\" and little ol \"Minetrois\"
Fellow Flashaholic, you guys have seens my terminial illness for lumens crave have been getting worst and worst. I used to be happy with a 20+ lumen MicroMag, then 80+ lumens "D-Pill", then 150+ lumens "FatMag", then 200+ lumens "Minetrois" and most recently the 300+ lumens "Quadamire". It seems like it an Moore's Law for flashaholism applies to me very very well.
I received several version of the Tri-Star from various sources. They were all very well built but not quite 100% of what I was looking for. Either the HS was too thin, too complicated, or plainly just doesn't work with the best current available reflector for their size. A major problem for those who attempt to assemble was clustering the stars. They move around and you just can't get it perfectly centered.
So here's my requirement/solution:
+ perfect auto centering of star & emitter.
+ more surface contact to improve heat transfer.
+ thicker plating to improve heat sinking.
+ reduce the cost so the everyday "modamag" can afford one.
Introducing the first of in series of "Perfect Mag Sink" ....
. The "Perfect Tri Sink" (aka PTS). (2/14/05)
and the second in the series ...
. The "Perfect Quad Sink" (aka PQS). (02/22/(05)
- Recessed pockets for perfect alignment of Tri-Star and Quad-Emitter.
- Increase heat sink height for maximum heat transfer.
- Protruding rear for optimal sink to MagD body.
- Designed to accommodate IMS SO20XA reflector for optimal throw.
o Micropores cooling for extreme apps (borrowed from semiconductor industry)
=== Pricing Schedule ===
#1C. "Perfect Tri Sink" for SO20XA reflector in MagC - Sandwich Shop
#1D. "Perfect Tri Sink" for SO20XA reflector in MagD - Sandwich Shop
#1CO."Perfect Tri Sink" for Fraen or NX05 optics in MagC - $12.01
#1DO."Perfect Tri Sink" for Fraen or NX05 optics in MagD - $11.98
#2. Tri-Star Kit - $75
....includes 1x PTS, 3x Luxeon III TW0J Star, 3x IMS SO20XA reflector
#3. Tri-Star Drop In Module - $80
....Prewired Kit with bi-pin connector
#4. Tri-Star Complete Assembly - $120
....Prewired Kit with FatMan Driver connected modded switch
#5. Tri-Star Shorten Mag2C TurnKey (aka "Minetrois") - $160
....Complete ready-to-run, just requires 3x CR123 or 2x Pilas 150s batteries.
....Availability pewter, purple, black.
....Dimmable available upon request
#6. Tri-Star Shorten Mag1D TurnKey - $170
....Complete ready-to-run, just requires 4x NiMh or 2x 14500 Li-Ion batteries.
....Available in pewter, copper, and blue.
#11C. "Perfect Quad Sink" for SO20XA reflector in MagC - Sandwich Shop
#11D. "Perfect Quad Sink" for SO20XA reflector in MagD - Sandwich Shop
#12. Quad Kit - $95
....includes 1x PQS, 4x Luxeon III TW0J Star, 4x IMS SO20XA reflector
#13. Quad Drop In Module - $105
#91. Modded Li-Ion Charger & 2x 14500 Li-Ion - $35
....Capable of chargin R123 or 14500 Li-Ion
#92. 3x IMS SO20XA reflector - $12
....Only available with PTS|PQS
* Please indicate which Mag host (C or D size) when ordering the Heat Sink.
=== Shipping and Delivery ===
All pricing includes S/H for US
International S/H please add $5
Custom order please allow 5 add'l days for completion
=== Payments ===
Cash PayPal: modamag_std[at]yahoo.com
Credit Card PayPal (add 4%): modamag_cc[at]yahoo.com
Please include your CPF handle and optic/reflector type in the PayPal note section.
Make a post in this thread with your order list.
* updated***
- separate PTS for easier/clearer ordering process
- add PQS to product line
- add Build Tutorial
Sway
North Carolina
Re: \"Perfect Tri Sink\"
Very nice work and at most excellent price /ubbthreads/images/graemlins/bowdown.gif any chance of the C sink or Quad I still haven't decided what to build yet.
Later
kelly
L
LITEmania
Guest
modamag :
Will Tri-sink also fit carclo's triple holder (for 3x 6degree optics)? If yes, I'm interested to buy some.
Warren
akula88
BisDak [Area X] ^^.PH
Modamag,
Which host is a minimum ? Mag2D is okey?
What light is made to host? Which batteries shall power this? Are 2x3AA-D included, or I could run 2xPila150s?
>> #5. Tri-Star TurnKey unit - $160
>> Complete ready-to-run, just requires batteries.
Inquiring minds needs answer /ubbthreads/images/graemlins/wink.gif /ubbthreads/images/graemlins/grin.gif
modamag
Bay Area, CA
These are available in "C" or "D" size, ready to ship.
Just indicate which ones you want when PayPal.
wallyrulz: "Are you going to make any for the 2C?"
If you mean "C" size for Mag2C then yes.
Sway: The Quad design is still being "tweaked". Normal Luxeon stars will not fit you have to file down the corner couple mils due to the break tab.
Warren: I designed these so they don't need the triple optics holder (more cost) to an already expensive item. But it will work fine with Fraen or NX05. Actually the beam is even tighter due to reduced spacing between the Luxeons. See what I mean /ubbthreads/images/graemlins/grin.gif
akula88: "Which host is a minimum ? Mag2D is okey?"
Any Mag host ... Mag1D-6D or Mag1C-6C will work.
"What light is made to host? Which batteries shall power this? Are 2x3AA-D included, or I could run 2xPila150s?"
First post updated with clarification for #5 & #6. And everything (3AA-D) is included in TK version.
L
LITEmania
Guest
[ QUOTE ]
[/ QUOTE ]
How we fix the optic onto Luxeon Star ? Any glue ?
Warren
cy
USA
I'll take two tri sinks. one for 2C m*g and one for 2D m*g.
what's your PP?
#1. "Perfect Tri Sink" slug - $11
Sway
North Carolina
PM sent,
Trigger finger on /ubbthreads/images/graemlins/takeit.gif /ubbthreads/images/graemlins/paypal.gif
/ubbthreads/images/graemlins/popcorn.gif
Later
Kelly
Sway
North Carolina
/ubbthreads/images/graemlins/paypal.gif Sent for 1 PTS and 3 TWOJ Stars /ubbthreads/images/graemlins/happy14.gif
Later
Kelly
yaesumofo
Eastern Pacific, LAX DM03 sw actual
I was working on a similar design for heat-sinking Luxeon stars(as opposed to emitters). My problem was setting the focus doesn't work well with stars when using reflectors. It didn't even occur to me to use an optic(OR three)Great Idea!! Are there any LARGE optics which would work with the mag head and a single heatsink mounted STAR? Hmmm...
Yaesumofo
KevinL
At World's End
a-w-e-s-o-m-e! A centered and recessed heatsink so that SO20XAs will fit a MagD - I remember I had some problems with my Mag3X-1D due to a miscalculation of the height on my part.
Well done modamag...
modamag
Bay Area, CA
* All paypal logged, will be shipped within 48hrs.
eTendue: No glue needed. There is approximately 15-20 lbs of clamping force from the lens.
Kevin: You should change your sig to say "Life begins at 200 lumens" /ubbthreads/images/graemlins/grin.gif
hotbeam: Just following your lead. Since X-bins can't be found, this is the next best thing.
yaesumofo: Large optics are available but at a $$$ price. I got some at work which are made out of saphire /ubbthreads/images/graemlins/thinking.gif that is able to withstand "plasma".
akula88
I'm interested on getting :
>....Complete ready-to-run, just requires 2x Pilas 150s batteries.
I'd like it to be dimmable. What host color is available?
EMAIL sent!
KevinL
At World's End
[ QUOTE ]
[/ QUOTE ]
But my U2 will then file for divorce /ubbthreads/images/graemlins/grin.gif
