Your light turned out very nice
I Like the floody P7 light - I use my magicshine P7 for commuting on High constantly (must be my age, that I need that much light
Would not worry about the housing temp too much (168°F = 75°C). A housing heating up fast means that the transfer from LED to housing is good, so that is a good sign. In my experience the lights heat up far less when some air is flowing over them, compared to 'on the bench'. I suggest you take some temp readings after a half hour ride and see for yourself.
PS: The 140°C limit for the P7 is the temperature of the die itself. This temperature is higher than that of the housing. Energy (heat) flows from the emitter to the surrounding air. Each material or junction between materials has its own thermal resistance, resulting in a temperature drop over this resistance. Just like an electrical current causes a voltage drop over an electric resistance.
So the maximum allowable temperature of the housing is less than that of the die (140°C), but depends on the amount of thermal resistance between the die and the outer surface of the housing and the thermal resistance between the housing and the surrounding air.
The better the heat conductive path LED to housing, the higher the temperature of the housing will be.
The better the heat conductive path housing to air, the lower the temperature of the housing will be.
Thermal resistance for the P7 is 3°C/W. About 20% of that is emitted as light. So at 9 Watt drive, the die will be 80% x 9W x 3°C/W = 21.6°C higher than the heatsink or PCB that the LED is mounted to. So absolute maximum temperature of the heatsink directly under the LED is 140°C - 21.6°C = 118.4°C. Of course, keeping the LED at lower temperatures increases LED life and efficiency.
For more information: See the
Thermal management Guide and P7 datasheet on this page:
http://www.seoulsemicon.com/en/product/prd/zpowerLEDp7.asp and I am sure that there are more than one thread in this forum on this subject. The picture above was taken from that guide.
To further complicate things for you: The constant current driver also has a finite electrical efficiency, and also creates heat that increases the housing temperature.
