luigi
Hello Everybody,
This is my review of the Pila GL2 with Cree LED and the Codex Module.
Let's start with the GL2
Pila GL2 Cree
The GL2 uses 2 cells, either two primary C123 batteries or a rechargeable Pila 600P battery AKA 18650.
It is built like a tank, you can drop it crush it hit it and abuse it in many ways and it will still be working as the first day.
This is the Cree note there are some space to install a tritium vial next to the led (idea!)
The Cree module is extremely bright producing about 130 lumen for 1 hour and a half on primaries or about 100 lumen for 5 hours with a 18650.
The switch is a tactical clickie with real momentary operation and great tactile response.
There are orings where they have to be and the threads are great, everything is very well built and strong.
The beam using a OP reflector is very smooth with a strong hotspot and a lot of sidespill, a very good balance between flood and throw, without going to either side, so it is good indoors, outdoors,etc. Probably one of the best Cree beams I have seen to date.
I loved the GL2 Cree is a very strong EDC light specially if you venture in the wilderness or need a very strong and reliable yet bright light.
Codex
The Codex is a programmable extension that goes between the bezel and the body, it has a LCD display with blue backlight.
The codex is a simplification of the ideas behind the never produced Indium Smart. You can program up to 4 programs (a,b,c,d). Each program is a set of frames (up to 9). Each frame indicates a brightness level (0%, 25%, 50%, 75%, 99%) and an duration from 0.0 to 9.9 seconds, the frames repeat one after the other.
So for example:
A single 25% frame of any duration is 25% constant on mode.
A 99% frame of 0.1 seconds followed by a 0% frame of 0.1 seconds is a strobe.
A 25% frame of 0.1 seconds followed by a 0% frame of 9.9 seconds can work as a locator beacon.
etc.
You can program sequences, messages, etc.
The programs are cycled pressing the switch in the codex module, the module remembers the last program that was activated and starts in that program. The Codex adds a battery warning indication with automatic brightness reduction to preserve runtime. It also has a built-in SOS mode that you don't need to program saving one program slot.
Pila with Codex. You can crush some bones with this!
There are several things I didn't like about the Codex:
- Only 4 programs, if you want four brightness levels that's it, no more modes for you.
- Strobe ratio can't be more than 5 hertz (0.1 seconds On, 0.1 seconds Off, repeat). Too slow to my taste to be effective.
- 25% is not low enought to preserve night vision, an even lower brightness level would have been useful to preserve night vision and even longer runtimes.
- The light flashes when it starts using Codex so you lose momentary activation (big no no) and furthermore if you want to start it in 25% you have to yet go thru a 99% flash that is very annoying.
- Too bulky for what it does and with the limitations it has
I loved the GL2 with Cree and the Codex is a very interesting gizmo to program your own custom sequences, to my taste the limitations it has are a big disappointment but I'm sure new versions will be improved and corrected.
Luigi
Pila GL2 Cree
Codex
So for example:
etc.
Luigi
