What would you recommend? anything on Ebay that is good?I would ditch that charge controller and get something better.
Norm
I see this controller also from the guy I bought the panel from.
Keep in mind the majority of the time, I'll be charging with the charger at home, the solar will only be used occasionally.
I am out of the city and most dealers are over a 100 K from me, so ebay is very convenient.
Norm
Chris I order Morningstar SHS-10 12Volt 10Amp DC Solar Controller.http://www.ebay.com.au/itm/Mornings...088&rk=1&rkt=4&sd=321188892638&#ht_4499wt_961
I might look at that one, as it's a major player in the solar controller game.
I pulled that number from the PowerSonic manual - they actually state 1.76. But yes, better agm's probably 1.2Your explanation for the 1.7 number is not accurate. This has nothing to do with efficiency compensation. A good quality AGM battery only requires 105 -110% of the capacity of the battery to fully and completely charge.
I might be over-cautious since I'm usually in 90F temps much of the time. My secondary concern that many forget is that sulfation isn't the only thing happening at low soc's - grid corrosion is also doing it's dirty work.You are overstating how dangerous running below 75% SOC is.
A bit more work on my battery box.
Three mm aluminium panel with meter, USB sockets, fuse and Anderson Power Poles still to be added. The finger hole is for lifting the paned which will be held down with Velcro. The meter isn't sitting flush, just trying fit. The panel will be painted black when all the metal work is finished, prior to mounting everything.
Norm
It's a fun project, no doubt.
Chris
It's is a fun project. Just wish there was an easier way to make square holes Chris, I've been starting the cut with my Dremel and then finishing off with a hacksaw and file.
Norm
Thanks for the suggestion, I do have exactly that nibbling tool, unfortunately it only good for 18 gauge / about 1mm my panel is 3mmYou might consider something like this, Norm.
Bill :welcome:Norm quick question what is the maximum panel that you can use with this controller ?l
