Changchung
I will be interested in saw some beamshoots comparing both optics. Thanks
I am a little busy at the moment but will try to take some soon. I have never taken beam shots before so will need to work out the setting. I am sure I will found some here on this forum.
cheers
Thanks Rat, I just want to see how much is the flood and the tight with the spot lens...
Ok I will try tonight. I liked it that much I purchased another one. The center spot is square but much brighter. It gives the whole beam a much brighter appearance with not that much in the way of flood loss.
cheers
EDIT: kerberos has the Quad XP-G 5.6A 3-mode P60 module 7th Run OPEN check his other thread.
Ok my first go at some beam shots.
The tint is whiter in my 10621 than the 10622 but they where both ordered as cool white maybe I got a warmer one by accident.
As you can see in the pictures the 10621 has got a brighter hot spot just look at the tree behind the main tree.
Both pictures taken with the same manual setting about 30 seconds apart.
Thanks for the beamshots, I thought there would be more of a difference between the two but I think I prefer the 10621 spot a little more. Which one do you prefer?
The 10622 flood
The 10621 spot
Hi Rod911,Back from my holiday, I went into work to pick up your drop-in and a brand new L2P with the A001 head and...it didn't work. The drop-in you sent me didn't have the larger outer spring and thus, no electrical contact was being made. I did get it to work by simply scavenging off another P60 drop-in's outer spring, so no big deal at the end.
It is still light here, so I haven't really gone out and tested the set-up yet.
