Reliable make/model/source for LiFePO4 cells in 16340 (RCR123) size
ronniepudding
NY Capital District
I just ordered an Xtar VP-2 charger, and I'd like to try out some LiFePO4 cells in my lights that take 16340 cells, but don't handle the higher voltage of LiCoO2 chemistry very well. I realize I'll be taking a big hit in terms of capacity, but in general I'm looking to use these lights around the house, so it won't be a problem.
Thing is, looking at the usual online flashlight vendors, the only such cells I see readily available for a reasonable price are Tenergy 400 mAh. I see some K2 cells on Amazon for ~$13, claiming 600 mAh -- which sounds like robbery and optimism, respectively. Doing some searches here, I see references to AW-branded LiFePO4, but that seems to be a thing of the past.
So, can anyone comment on the quality of the Tenergy cells? Any better options I should consider? Are the K2 cells really 600 mAh, and/or worth 4x the price of the Tenergy cells?
Thanks!
Nichia!
Banned
No, never used them. But since Surefire recommends these I guess they will be fine.
Tachead
Northwestern Ontario, Canada
I have a couple of the Tenergy ones and have been using them for a couple of years sporadically. They aren't super high capacity but, they work well and have held up fine so far. I would buy them again.
xxo
I use the k2'S and they work fine, never tried the tenergies. I got the K2's because they are supposedly(?) the best. Runtime is roughly half what you get with CR123's.
ronniepudding
NY Capital District
Thanks Tachead... since the Tenergy cells are on sale right now (Cyber Tuesday) for less than $3 each, I'm going to order a couple of them tonight and see how they work out.
ronniepudding
NY Capital District
I received my order today, and got to try out the Tenergy cells in a few lights. Preliminary results are good, they work well in most of my older lights that don't dig the higher voltage of Li-Ion...
— Eagletac D25C modes are preserved with 'proper' spacing (i.e., as they are with CR123A);
— Foursevens old Mini ML, no issues;
— my Olight S10 Baton, which for some reason has never worked with RCR123... worked fine with LiFePO4.
Only disappointment was FourSevens Atom AL... Tenergy cell length is a hair too long, and high mode won't work without tightening the head excessively.
