retired Instruction Manual - a joint CPF effort
Status
Not open for further replies.
jch79
**Do Not Feed The Vegan**,
On the asphalt.
Re: SPY 007 Instruction Manual - a joint CPF effort
Chevrofreak was kind enough to send me the graph files for his runtime tests, and I finally was able to get them opened. I'm going to edit them and make two charts, one for levels 1-2-3, and one for levels 4-5-6. This looks much better IMHO.
Hods, I'm not sure if the light is meant to be run at 1250mA for the duration? Dave?
:thumbsup: john
PoliceScannerMan
Gainesville,FL
Runtime at 1250mA would also be interesting - it seems to rip through primaries.
I'm more than happy to fund the battery usage but don't have the kit to produce runtime graphs!
I would advise against that, unless you are good at replacing emitters! I would think a solid runtime @ 1.2A would ruin the emitter.
jch79
On the asphalt.
If you got em, smoke em! :D
jch79
On the asphalt.
Post #2 updated with new runtime charts created with Chevro's data! :thumbsup: I split 'em up into two charts, to perhaps provide more clear results.
:) john
Scottiver
California
:) john
Ah, much better now, thanks! :twothumbs
jch79
On the asphalt.
I really do have better things to do (like work)... but is work really "better" than playing in Photoshop??
Spy 007 Instruction Manual - Halloween 2008 Revision! (Actual changes were made as well)
:D john
Hodsta
EDITED: one for the question thread.
X_Marine
Houston, Tx
I believe Data requested a cropped pic of the split ring for the manual.
Hope that is small enough.
Thanks
X/BillyD..
reptiles
Philadelphia PA
Under Care & Cleaning...
I have been using on my Spy 007 with a Foaming Glass Cleaner that is safe for Tinted Windows with a Microfiber Cloth.
It really brightens up the Ti and won't scratch at all.
Also no lint.
FYI...
I use Mother's Chrome Polish (at any automotive store) on all my titanium lights. My Spy007 never looked better after a 20 min. buffing.
Cheers,
Mark
reptiles
Philadelphia PA
Please consider the following addition for section 2 Changing Batteries:
Before placing new batteries into the Spy007, ensure that the rotary switch is in the "off" position by turning the knob fully counter-clockwise (facing the flat top of the knob.)
Regards,
Mark
jch79
On the asphalt.
Thanks Mark! :wave:
We put this in section 2:
"When changing batteries use power-up-0 (the switch set to the off position)."
:) john
Hodsta
Thanks Mark! :wave:
:) john
PATE NATS to you John:nana:
That's Positive At The Emmiter, Negative At The Switch. I like to add a little Gaelic tone and in my mind and add circumflexes and accents as appropriate but can't find them on my keyboard.:shrug:
Clearly pate can be mushroom or ardennes depending on your sensiblities:D.
jch79
On the asphalt.
Speaking of mushrooms... Hods, have you eaten any strange-looking ones lately?? :poof: :duh2: :whoopin:
:nana: john
Hodsta
:mecry:
Anyone got a good nmemonic to help me remember which way to put the cells in? My memory isn't what it was, must be all those drugs!:p
reptiles
Philadelphia PA
Thanks Mark! :wave:
:) john
Ok, looks better now, thanks :) I like the addition of where "off" is located in that section.
Although the term "power-up 0" isn't introduced until section 5 and probably doesn't mean much in section 2.
Regards,
Mark
jch79
On the asphalt.
Good call Mark - I'll put a "See section 5 for more info" on that. :thumbsup:
Data
PA, USA
:mecry:
You could, if all else fails, look inside the light! :p
Hodsta
Yes, thanks Dave!. Funnily enough I mostly (though not exclusively) use my Spy in the dark!:p
Status
