@Ven,
Indeed, I also noticed that mine wore out a lot quicker than other lights I've had even though I don't attach it to the keys. Probably the anodizing is just not that perfect, but apart from that, the light is awesome
Anybody else notice knurling on new tool AAA is a lot smoother. I had a 70L model which I lost and purchased the newer 110L model, feels totally different. I miss the old knurling.:shakehead
Yes, the same change happened to the Maratacs. I like the new smoother knurl, the old one I found too sharp.Anybody else notice knurling on new tool AAA is a lot smoother.
… The knurling is far less aggressive….
I noticed immediately that it was neither as bitey... The knurl on [old version] is a diamond pattern with a dot. The [new version] is missing the dot, and has been buffed pretty smooth, no sharp knurling at all.
Much just be me then. Looks like must people prefer smoother knurling. Guess thats why Lumintop and maratac changed to a less aggressive knurl on there newer lights.
… Efest 10440's … will not power on the light. …
ultra fire 10440 … does work
Maybe ask Vinh why he chooses IMR10440. Also read this post in which Vinh explains why it is a bad idea to use 10440 with a stock Tool driver...
The driver is the new PWM free version as evident by the ring around the LED and the circuit itself, like the Maratac Ti and Rev 3.5 Cu.
The Nichia 219B produces a very pleasing beam in this setup with a smooth transition from the hotspot to spill. The particular LED appears to be a little warmer than my D25A's 5000k Nichia, though still quite a neutral white appearance.
The sequence for this retail unit is M-L-H, 18-3-80, which I personally find agreeable for EDC purposes, though some will lament the lack of a lower low and starting in Medium as opposed to low.
As previously noted the knurling is different from previous Tools and Maratac AAA's.
