Yikes Badbeams3! I share your pain.
What was your failure?
Could be a batch problem or something.
Now this is getting worrying.
You could try emailing Klarus support and see if you're able to do an exchange with a local dealer near you.
When the tail is screwed on the light come on at a low level (without pressing any switch)....maybe 3~5 lumen. Press either switch and it switches to a bright level...and then it freezes. Will not change modes or turn off.
I emailed Best Gear and, like you, they sent me back an email saying I would get an another email within 24 hours (except for weekends) on how to proceed. Then just a little while ago I received this email....
Thank you for contacting Gearbest.
We sincerely sorry to hear this about your item.
We would like to work together to resolve the issue to your satisfaction.
Please review our warranty here:http://www.gearbest.com/about/warranty-and-return.html
Therefore we kindly ask you to follow these steps:
1.Please describe the problem with your item in details (what happened and when?) stating your order number.
2.Please tell us what steps you have already taken to solve the issue.
3.Please give us the item code indicated on the outer package.
4.Please send us clear picture or video of the defects in good lighting.
Please keep the attachment below 2MB and use any of these formats gif, jpg, png, bmp, doc, xls, txt, rar, ppt, pdf.
We will do our best to help you.
We look forward to hearing from you.
Thank you for your cooperation.
Best Regards
Rafael
Gearbest Customer Service
I responded...again...
"When I screw the tailcap on, the light comes on at a dim level (without pressing either of the switches), perhaps 3 lumen. When either of the switches is pressed the light moves to a high level (I think turbo, but not sure)...and then freezes. Will not change levels or turn off without unscrewing the tail cap. I have repeated installing the tail cap after double checking for proper battery polarity and pin alignment with no change in results. I don't know how to send video, But there is nothing to see that I have not described. The light looks to have arrived without any visible damage to the box or light. The model is a Klarus G30. Please advise me of how to proceed to return the light to Gearbest.
Thanks
