kreisl
- Joined
- Jul 5, 2012
- Messages
- 2,244
i got the polished version now and since i like it so much i feel motivated to share my own quick thoughts.
weight measurements on my +1g kitchen scale, feel free to compare with official specs:
O'Pen : 22g (w/ preinstalled clip)
LD12G2: 52g (w/ preinstalled clip)
LD01 : 14g (w/o clip)
LD01SS: 35g (w/ mini split ring)
TiS : 24g (w/o keychain, w/o clip), 26g (w/ keychain, w/o clip)
MiX6SS: 17g
WormSS: 27g
SP11SS: 23g (w/ mini split ring)
K18SS : 30g (w/ preinstalled clip)
what's not so good:
- arbitrary alignment of tail loop versus switch location (EDIT: i got perfect alignment on my 2nd K18SS unit!!)
- clip was preinstalled, hmm.
- clip is same as in other lights (Olight AAA, TiS). i won't use it because i don't think that it attaches securely to the light or that it can withstand notable force. there are several reports of similar clips getting lost or breaking off. yes you can attach it nicely to a shirt pocket, but i wouldn't seriously try it on a hat (baseball cap) and for sure(!!) not clipped to pants pockets. clearly, Olight AAA/TiS/K18 pocket clips are not strong clips in any respect.
- weight. imho unacceptable for actual keychain carry. my personal limit was reached at 23g. (EDIT: i got a 2nd unit and have started to EDC it, we'll see)
- i don't believe in the durability or longevity of the switch rubber; it's just a believe though.
- switch rubber 'MODE'-label is misaligned (as seen in the review). that's nitpicking, though. (EDIT: it's perfectly straight aligned on my 2nd K18SS unit!!)
what's not so bad imho:
- the arbitrary alignment of tail loop versus switch location isn't so bad because the threads are not anodized, which means that one does not need to fully tighten the head! posers like kreisl could simply twist the body a bit until perfect alignment is reached.
- general looks. has similarities to LF2XT
- polished like TiS
- tail. looked shocking on pictures but is cute & unimposing in RL. was a concern, not anymore.
- in theory as long as LD01 but feels shorter
- PWM in Low and Med. easily detected thru rapid hand fan movement. it is high frequency but ppl who really hate PWM at any frequency level should steer clear. it's high frequency, so it's not bad. i've seen higher frequencies though in other PWM lights!
- my protected grey UF 10440's don't fit. their length is 47.03-47.11mm. but it's not too bad because a copper washer (conductive spacer ring) is not needed since the threads are not anodized
- clip is, in theory, reversable. in practice, i wouldn't rely on the clip; it's not as strong as a Fenix LD01 clip. it's not so bad because for keychain duty i have removed the clip. i could leave the clip on for decorative function but i would not dare to use it/rely on it other than for office shirt carry.
- premium-like packaging. includes generous set of accessories (see also comment on o-rings).
- from UPz's review: good efficiency on NiMH and 10440. There is a handful of lights (like Maratac Copper AAA) with higher efficiency on NiMH but except for the D25AAA none of them is compatible with 10440's.
- all 3 supplied o-rings (1 installed, 2 spares) were imo too small. o-ring thickness should be 1.0mm, agreed. However the correctly fitting o-ring size would be 9.0×11.0×0.95mm (tested, OK), 9.0×11.0×1.05mm (tested, OK), 10.0×12.0×0.95mm (tested, OK), or even 10.0×12.0×1.05mm (untested, assumed OK). Luckily i found such an o-ring in one of the small accessory bags of my AAA lights, so it's not so bad. (EDIT: my 2nd unit came with 10x12x1mm o-rings, perfect!)
- my polished version deserves a mini pouch/holster/case. i got 2 copies of the very well-made well-built Eoslamp pouch, it's a perfect fit. that mini holster would be suitable for belt carry but i use my flashlight holsters only for bag carry. the entire product exudes premium feel, so why not include such a mini holster in the packaging? since the Eoslamp pouch isn't soft, it does leave micro scratches in the polished finish, hmm.
- has a serial number printing. nice touch.
- new brand by a young company. who knows if they'll still be around in a year or if anyone cares then. says 2.0yrs warranty. choice of brand name unfortunate, UltraTac almost sounds like UltraFire which is an old and infamous brand.
- tailcap lockout or head lockout is not possible because the threads are not anodized. only electronic lockout is possible: double-click from OFF state. I'd prefer triple-click for reactivation, as seen on Nitecore D11.2 flashlights.
- the light has mechanical reverse polarity protection, meaning that the plus(+) metal contact of the driver disc won't be touched/reached by the negative(-) flat terminal of the AAA battery. In other words, if a battery is reversely inserted, there will be no voltage (right direction voltage nor reverse direction voltage!) connected to the driver disc. The driver disc will be "voltage-free". However, since the threads are not anodized and the spacer ring is conductive (looks like a brass ring or so), a reversely installed Eneloop will be shorted. I have tested it! Basically, your battery (Eneloop) will be harmed, but not the flashlight itself.
- max. brightness on Eneloop is spec'ed as "110lm" (UPz had measured 97.9lm 30sec after activation on a full battery). I can tell from visuals that K12SS("110lm") < TiS-nw ("120lm"). TiS-nw is notably brighter than K12SS, both on Eneloop. But "120lm" are spec'ed for "0.5h" runtime whereas the "110lm" for 1 hour" (UPz had measured ~55min). So yes, the TiS-nw is brighter during its entire runtime period but its runtime is also notably shorter than the 55min.
- 2.0yrs warranty. unbelievable.
what makes this a winner, a keeper forever:
+ precise concentric boring. thickness of male threads, measured at 4 spots (spaced 90° apart) around the circumference: 1.12mm/1.11mm/1.12mm/1.11mm, i.e. tolerance of ±0.005mm.
+ in general, exquisite machining, with rounded edges everywhere
+ silky smooth threads, "no" head wobbliness (well, compared to competitive lights).
+ protected 10440's of any length work since the threads are not anodized. no copper washer needed!
+ perfectly centered LED, perfect beam profile, no artifacts, no (pronounced) corona
+ best tint. no greens, no yellows. tint looks uniformly one color: antarctic cool white (=artificial pure white with purplish spill). i've seen this kind of tint on other XP-G2 cw AA lights before (d25a clicky ti xp-g2 cw, T10S xp-g2 cw) but it's the first time that i see it on an AAA light.
+ no tint shift on Low and Med. probably due to the PWM?
+ super bright on 10440's and nothing to sneeze at on NiMH.
+ absolutely likable, from the beginning to the end
+ what adds to the likability is its affordable retail price. i feel different, less enthused about a great product, if i pay much money, an unfair price for it, but that's just me.
I don't care for anodized keychain lights anymore. I retired my beloved black LD01, a 40$ flashlight om*g!, a while ago when i noticed abrasion of the anodization, and even the E09 cheapo is too nice to be banged up. So now i am all in for SS AAA lights, copper and titanium aside. The TiS starts with Firefly and it is a hassle to twist thru the modes with 2 hands until you're in High mode. However it is a winner and keeper for its great NiMH performance, very light SS weight, beautiful NW tint, and popularity, i might rank it even higher than the K18SS.
I wouldn't enjoy the K18 in anodized version but in SS it's imho a completely different game. To sum up the most striking points, the K18SS is a keeper for its bright beam, superb tint performance, pretty good driver efficiency, amazing build quality/machining — all Pro's which it shares with the TiS xp-g2 nw — and what makes it extraordinary are: the UI (incl. 1-handed operation and mode memory), official support of 10440, and lucky support of protected 10440's. In RL/in practice, the length, the tail loop, the clip (100% identical to TiS clip!), the PWM are imho of no concern. The only grave downside to be called out is imo the weight. My personal limit for actual EDC keychain duty was 23g (without battery) and i can indeedy feel if the light weighs 27g, 30g, or crazy 35g instead. Luckily a blue unprotected Ultrafire 10440 weighs only 8.5g, as opposed to Eneloop AAA with 11.7g, which accounts for a 3.2g difference.
SP11SS+Eneloop = 23g + 11.7g = ~34.7g
K18SS+UF10440 = 30g + 8.5g = ~38.5g
=> weight difference ~3.8g or 11% increase. Okay, that sounds acceptable on paper, i could live it.
Bottom line is, my K18SS is going to stay in my collection Pelican case most of the time. I will carry it sometimes in shirt or jacket pocket when i plan to use it that night, e.g. for showing off, showing to friends.
I highly appreciate the existence of this SS light, am thankful for the successful creation. I bought my unit from HKE thru ebay and i am thinking of getting another unit to see how it holds up during actual keychain duty. Btw i also own 2 units of TiS, both in mint condition.
MiX6SS: 17g
WormSS: 27g
what's not so good:
- polished like TiS
