Safe power shut off.
trimixdiver
Brisbane Australia
lucca brassi
US
don't understand why such protection module ?
Pack is normally discharged with value same as charged that mean 20% C which is in your case 1 A ( talking for smart charger/ discharger )
Direct (rapid ) discharging depends on battery properties ( inner resistance) and is marked on battery
arek98
New Jersey, USA
Are you building pack yourself from loose cells? Make sure they have similar performance - same brand, type, capacity (nominal and actual), age.
You need protection circuit for 14.8V pack. Get one with balancing function.
You need to solder balancing wires at each end and between each pair of cells (5 total - 2 at the ends will go together with charging wires).
Balancing wires can be thin but not to thin (AWG 22 would be probably my choice), they allow protection circuit to control voltage of individual cell (2 cells in parallel are threated as single higher capacity cell) and push smaller charging current when balancing cells.
I would not go for pack without balancing for more than 2 cells in series.
Something like this
If you get circuit without balancing you should still solder balancing wires and add connector. Then use balancing charger as often as possible.
