Sold/Expired SALE FM1909 G4 HALOGEN 2260 LUMENS
fivemega
California
[SIZE=+2]
( C L O S E D )
[/SIZE]
Custom made FM1909 bulb.
11.4V -- 5.5A -- 63W -- 2260L -- 20 Hrs Life -- 3400K temp.
http://i61.photobucket.com/albums/h75/pike444/bulbs/FM-CL1909.jpg
https://www.candlepowerforums.com/posts/3064950&postcount=344
Price:
Pack of 4 bulbs, $68 shipped in all 50 States. (No discount applied).
Please add $4 for shipped anywhere else in the world.
This is an official thread for custum made bulb which was opened on Dec-9th 2013 and closed on March 1st2014.
If you are a LED guy, I suggest you buy some of these and make yourself an incand guy :D and experience warm blinding beam of Halogen.
Please make sure write a note of item you are paying for and your CPF ID handle in paypal.
I will never figure out who is paying if payment received with no note.
Your post is necessary here unless you don't order. So make sure first pay correct amount to provided Paypal address, then post your order here immediately.
For example: Miss. Ashleyfire sent :paypal: for a pack of 4 FM1909
Paypal:
[email protected]
[SIZE=+1]Excellent host: 3x26650[/SIZE]
[SIZE=+1]Compact Host: 3x26500[/SIZE]
[SIZE=+1]Economy host: 3x26500[/SIZE]
[SIZE=+1]Megalennium B host: 3x18650[/SIZE]
[SIZE=+1]Complete flashlight: 3x26500[/SIZE]
[SIZE=-3]#01 set of 4 FM1909 tomthebaker paid shipped 9114901159815961076939
#02 set of 4 FM1909 tomthebaker paid shipped 9114901159815961076939
#03 set of 4 FM1909 fredx paid shipped 23082940000035337788
#04 set of 4 FM1909 dbleznak paid shipped 9114901159818848909030
#05 set of 4 FM1909 Bimmerboy paid shipped 9114901159818848909054
#06 set of 4 FM1909 walterr839 paid shipped 9114901159815396154806
#07 set of 4 FM1909 dinokay paid shipped 9114901159818848909078
#08 set of 4 FM1909 dinokay paid shipped 9114901159818848909078
#09 set of 4 FM1909 william lafferty paid shipped 9114901159818848949487
#10 set of 4 FM1909 Colonel Sanders paid shipped 9114901159815942864470
#11 set of 4 FM1909 Colonel Sanders paid shipped 9114901159815942864470
#12 set of 4 FM1909 KiwiMark paid shipped LC658424101US
#14 set of 4 FM1909 Onibi paid shipped LC435915495US
#15 set of 4 FM1909 Onibi paid shipped LC435915495US
#16 set of 4 FM1909 william lafferty paid shipped 9114901159815942785584
#17 set of 4 FM1909 TurboLou paid shipped 9114901159815876935796
#18 set of 4 FM1909 Bimmerboy paid shipped 9114901159815876935826[/size]
[SIZE=+1]Please find link of my other products [/SIZE] [SIZE=+2]here[/SIZE][SIZE=+1] and click on each link you are interested on.[/SIZE]
[SIZE=+4]
( C L O S E D )​
[/SIZE]
fivemega
California
***QUESTIONS***
I love these bulbs with 26650x3, = 11.1v
What is the output with 9x1.2v eneloop = 10.8v?
will they have a longer life at 10.8v?
what about 12*1.2v = 14.4v. Different bulb? Which one?
Obviously, output will be less with 9AA but longer bulb life.
Best set up with AAs is 10AA but will flash on 12AA
Please note that this bulb needs about 5.5 Amps of current which is maximum for Eneloops.
For any other higher current setup, you will need to use high current AA cells or different chemistry.
For 12 Eneloops, brightest bulb I experienced is Osram 64611
To use 100 watt Osram 64623, 12 high current AAs will work but 13AA (if you can accommodate) is even brighter.
Please note that all above statements are based on direct drive and average system resistance.
I know you say this bulb is designed around 3xIMR at 11.1V. But how would longevity be with 4xIFR with 14.4V fresh off the charger and a 12.8V plateau? Would I want to let the cells rest after charging? And would 12.8V have a VERY adverse effect on longevity? The cells are A123 Systems 26650s. So voltage sag will be minimal at 5.5A.
I don't recommend more than 11.5 volts to bulb pins.
You may have 12 or 12.8 volts at battery terminal under load but 11 volts at bulb terminals which is OK but anything more than 11.5 volts may (or may not) flash the bulb.
Again, this bulb designed for maximum of 11.5 volt and can't handle much overdrive.
Let's take it this way: At 11.5 volts it's already overdriven to maximum voltage that it can handle.
So if using a JimmyM hotwire regulator with a slow start, I should have it set no higher than 11.5v or might there be a little voltage loss before hitting the bulb?
According to this test, you can see that there is not much room for over-overdriving. Maybe few tenths of volt with very slow ramp up voltage to bulb pins.
Is an AW soft-start switch required to use the 1909?
No. It's not required but won't hurt to use.
Do you think 3 x IMR 16340s is ok?
Please read maximum continuous current draw of IMR16340 here, then you tell me.
How about 4x123s primaries ?
5.5 Amps on primary 123 is not acceptable.
for future reference, is the G4 a bi-pin bulb that'd work in your Surefire M6 bi-pin adapter?
fivemega said:
FM, I have an FM1909 bulb coming my way from CPFMP. That being said, I also have a "Black Edition" PhD M6 with the highest voltage setting on it being 10.8v.
That 10.8v setting is acceptable for the FM1909 bulb, correct? I don't want to risk flashing the bulb is why I ask.
Thanks man!
FM1909 will be slightly underdriven but will be bright enough.
My main concern is high drain from your Li-Cobalt 17670 cells.
dbleznak
Philly
#4 dbleznak $54.40 Transaction ID: 78F88232PJ798711K
Will these work in a KT1 head?
fivemega
California
Please read entire post #1 here.
[SIZE=+4]Lens and bulbs are excluded.[/SIZE]
[SIZE=+3]Lens and bulbs are excluded.[/SIZE]
[SIZE=+2]Lens and bulbs are excluded.[/SIZE]
[SIZE=+1]Lens and bulbs are excluded.[/SIZE]
[SIZE=-1]Lens and bulbs are excluded.[/SIZE]
[SIZE=-2]Lens and bulbs are excluded.[/SIZE]
Bimmerboy
Long Island, NY
Mr. Bimmerfire sent :paypal: for a pack of 4 FM1909.
Been looking forward to these for a long time. Thank you very much for making these available again, FM!
Bimmerboy
Long Island, NY
Hi, FM. Just realized I'd better ask if my post saying "Mr. Bimmerfire" caused any confusion, and delayed shipping. Couldn't resist because I get a kick out of the fake names you use in the sales threads.
I put the correct name in the paypal if it's any help. Thanks!
dbleznak
Philly
Second payment for #4 made by dbleznak. Transaction ID: 01M63338HF5582818
Thanks
tomthebaker
Thanks.
fivemega
California
Thanks.
StorminMatt
Norcal
fivemega
California
You may have 12 or 12.8 volts at battery terminal under load but 11 volts at bulb terminals which is OK but anything more than 11.5 volts may flash the bulb unless you are a lucky person.
Again, above statement is based on direct drive.
Colonel Sanders
ROLL TIDE!
Colonel Sanders sent $136 for 2 packs of 3 FM1909 bulbs! :cool:
So if using a JimmyM hotwire regulator with a slow start, I should have it set no higher than 11.5v or might there be a little voltage loss before hitting the bulb? Just trying to make sure I get the most out of this bulb. Thanks!
Bimmerboy
Long Island, NY
I might be able to help with this one (thanks again, DIWdiver for jostling my memory and making me go actually read Jimmy's thread again). Someone correct me if I'm wrong.
With the regulator, the bulb will see full pack voltage (minus resistance losses) averaged down to a "lower voltage" using PWM. Since Vbat delivered to the bulb will be higher than spec, losses are pretty much factored out of the equation. Therefore, set your Vbulb to whatever you want using LuxLuthor's 1909 chart provided by FM above. You might be able to get away pretty well with a little extra overdrive, especially if you're using the "slow start" option on the regulator.
Happy hotwiring!
KiwiMark
Waikato, New Zealand
Hmmm, I do love my Mag 3D with 3 x 32650 cells, AW soft start driver, FM Bi-focal reflector, UCL lens and FM-1909 bulb - such a nice flashlight with really nice output.
I suppose I should get some spare batteries while I can.
So it is $68 for 4 bulbs + $4 for overseas shipping = US$72
Paypal sent! :paypal:
onibi
I like all the high or low incandescent bulbs.
2 pack order was placed.
Paypal sent:)
