I haven't looked at these in a while. I'm holding 3 for maxspeeds. But I'm not sure about more.
If Maxspeeds doesn't respond can i get 2?
There are 2 parts. The voltage regulator and the FET. The tricky part is the voltage divider used to measure the battery voltage. If you just use a voltage regulator to drop the voltage going into the regulator at the vBat input, the regulator will always see that reduced voltage and not the actual battery voltage. I'm not sure how his results worked out. You'd probably have to switch out one of the voltage divider resistors to allow a higher battery voltage to sampled without overloading the ADC pin. The specs on the FET he used look OK. A better one might be found today since his post is 9 years old now.I have been thinking about modding one of my regulators to wor with higher voltages like was done here.
Did he do it correctly?
I searched for these parts on Mouser and got results, but there are multiple versions of the voltage regulator with slight differences and I don't know which specific characterics are needed. Can you help me?
I just looked up the part number he used in the thread you linked. Basically, you want a 60V mosfet with a logic level gate (5V gate) and as low as possible Rds(on). The one I use is 3.8mOhm I believe. Is your intent to re-solder one as a replacement on the board? If so, you want the DPAK package size (not DPAK2). The new voltage regulator will step down your battery voltage to 7V-35V for the regulators onboard regulator to take over from there. 12V regulators are easy to find. The catch is that you'll have to replace R1 with a higher resistance value (it's 357K now) so the uC can sample the battery voltage correctly. Something in the 510K area should work depending on your max battery voltage. Then you need to cut the trace going from R1 to the center connection and input your battery voltage directly to the R1 side of the cut trace. It's not a little thing you're trying to do. If you accomplish all of this, it may not fit under the KIU socket base any more.Do have all the specs written down somewhere? I'm not quite sure how to go about this...
I need a voltage regulator of type X whcoh does what?
I agree. That thing would be a monster.Thanks for your help Jimmy!
I don't know yet what I will do with this regulator that I have left. It just seemed like a nice idea to try out a 400W bulb.
