Unforgiven
I don't think the channels are fully independant. I think they are pairs chared parallel instead of series unlike most paired chargers. This is why you see the two different charge rates. This configuration allows single battery charging at the 2 amp rate or two batteries @ 1 amps.
Not an uncommon configuration. Do not charge pairs with different discharge states. One will get over charged and the other undercharged.
This was not the experience with the MQH03 that I own.
According to Sanyo's instructions this charger does not charge at two different rates simultaneously unless AA and AAA are charged at the same time. AA cells would charge at 2 amps when only using outer bays and AAA would charge at 800ma while using the outer bays. If either or both of the other 2 inner bays are used then all cells will charge at their respective lower rates. (1amp and 800ma)
When I first received my MQH03, it was tested with various battery configurations including mixing AA and AAA while using different bays to charge then discharged on the C9000 to test for capacity. During the charging none of the cells over heated and all cells tested in their average respective capacity ranges. It appeared to charge equally well when charging from one to four cells at a time with either the same or mixed size batteries.
If the cells charged at different rates and terminated at the same time, it would show in the temperature of the cells and/or their capacity when discharged on the C9000
If your MQH03 exhibits the characteristics you described then perhaps you have a faulty MQ03 and should contact Sanyo.
