Well, I ran a second Seoul P4 thru the same drive levels, it doesn't get nearly as blue, but still shifts around.
The more and more I fiddle with these parts, the more I realize the consistency is not like the Luxeons.
Personally from what I see so far, if I were buying the Seoul P4 in a flashlight, I think myself, I'd really want to try out a batch of them, and choose the pick of the litter, unless it was a 10 dollar flashlight (and then, I'd still be tempted).
So, from what I'm seeing out of my first batch... For some, it is possible that they may get a premo choice part, and they will feel they are as good as a Luxeon (or better, since it is a lot brighter than the Luxeon). Others may get not so awesome of a part, and they won't be all that happy about it, especially those that have some conerns over tint and tint variation. Right now, about the only idea I can think of, is to ask specifically for the full ranking of the parts that comes off the reel, Flux, Tint, and Forward Voltage for the flashlight they are put in- or to ask what tint bin the flashlight is in at its rated current- like SYN @ 1100mA (roughly like LumiLEDs YA) and then what bin it falls in at it's dim current, like SUM @ 50mA (LumiLEDs UM bin).
For those that haven't seen it yet, due to tint requirements of customers, LumiLEDs has moved to tighter bins, back in May of 2006, so the chart above may be a surprise.
I understand that Seoul Semiconductor offers sub-bins, however, I've never been able to buy a single bin. The ones I've gotten so far are by Kelvin temp (6500K), which leaves you pretty wide open. Possibly if one was able to purchase a single bin, the variation from part to part would be less, and I think if I was buying an expensive light with the Seoul P4, I'd really like the bin stated.
I'm not sure at what current Seoul bins the P4 at but when I get them directly from Seoul, on the package, you will see USW0H, where U = flux 91-118 (LumiLEDs 87.4 to 113.6), SWO basically equals LumiLEDs WO color bin, and H is the same as LumiLEDs Vf H bin, but 0.03 Volts lower.
I'm currently unsure at what current Seoul bins these at, but since the datasheet has it's Electro-Optical characteristics stated at 350mA, possibly it is done there. They also show the Relative Light Output vs. Junction temperature @ 350mA. Unfortunately, at other currents, white LEDs only generally track, and it isn't possible to specifically nail down exactly what the LED is going to do at other currents.
When soldering the slug down, if the part has not been in a sealed dry atomsphere, and they have been outside the sealed dessicant package more than 1 week, you will want to bake the parts for 10-12 hours at 60C before soldering the slug down. When washed, they recommend Isopropyl Alcohol. They recommend that if you are storing them for more than three months after shipping from SSC, that you store them in a sealed container with dry Nitrogen. Long term exposure to sunlight or occasional UV will cause lens discoloration. Avoid leaving fingerprints on the silicone resin lens. And they do not recommend covering the silicone resin lens with another resin.
Possibly, with higher dollar lights, we could get the makers to provide a tint variation plot with current or something. It would not need to be exact, only what the light typically does. IMHO, this would be helpful for these parts.
Meanwhile, I'm going to work on a video with a different Seoul P4 part to try and show you what I am talking about.
Overlayed bins:
