could you please elaborate about how to estimate run time? say i have a flashlight that is drawing 1 amp but i am using 2x RCR 123 or 1x 18650 how would you guess run time? thanks a bunch!
Ohhh isee! one more question..> if my flashlight uses 2x RCR-123 and one RCR-123 is rated at 880 MAH would i double that? or would it be 880 MAH? soo this light is drawing about .6 so i assume thats 880/.6 = 1466.6666? or 2933.333? and i asume thats 1.46 hrs or 2.93 hrs? thanks a bunch !
just want ot ask....
circuit & conection resistance will show up under load. is there a problem measuring it (ie wire from +batt to +board) will the flashlight/circuit is running?
Also never use the resistance setting of a multimeter on a live circuit with current flowing through it.
Do you want to measure resistance in wires and switches?
This is a very low resistance and requires a special technique to measure and is not covered in this guide. If there is a need for it I can add it to the guide.
let me guess ...parallel metering with a know value resistor?
Just a question, even if it turns out to be nonsense...
Can I have a DMM with all 3 leads connected while measuring (Current and Voltage alternatively)
My purpose is to monitor the Li-Ion charger with one DMM only. So if I connect the elads correctly will it matter is for example, current is flowing still through the 10A socket while the Dial is turned to voltage metering?
Thanks, kostas
......If you forget which lead is which and accidentally connect the current probe to the wrong place you will blow the fuse in the meter.
