Small current doesn't flow through multimeter set to 200 mA but does when set to 10 A
seanspotatobusiness
I wanted to see how much current was going through a regular LED at a certain voltage. It should have been 20 or 30 mA. I set my multimeter to scale 200 mA and wire up appropriately and the LED does not light - no current flows. I then take the lead out of the red socket and plug it into the yellow socket which allows up to 10 A. I switched the multimeter to the 10 A setting. The LED lights and the current registered as "0.01" A which is of course not very accurate, hence me wanting to use the 200 mA setting. Any idea why it's not letting me use the 200 mA setting? My guess is some sort of protection against too-high a current, but this protection should not be getting activated.
Norm
Retired Administrator
Australia
Is it possible the 200mA range on your meter is faulty or been damaged in some way.
Norm
Bullzeyebill
CA
Depending on a DMM model, the 200mA range setting is usually fused. Check the fuse.
Bill
selfbuilt
That would be my guess too. I'd had two DMMs stop working on their mA ports. Once was definitely my fault - ran a >1A load through it by mistake (tried changing the fuse, but no effect - so likely damage to the circuitry). Second meter was a mystery (haven't tried changing the fuse, but I know I didn't subject it to anything unusual).
It your meter has a continuity measuring feature (often audible), check to see if the port is actually working. If not, you could try swapping the fuse (they usually only cost a coupe of bucks).
recycledelectrons
It could be the terminals have to be in a different location for 200mA than for 10A.
Do you have a manual handy?
Bullzeyebill
CA
No feed back from OP, which is curious. I'll close thread if he doesn't respond soon.
Bill
seanspotatobusiness
Yes, it was the fuse. Thanks very much for the responses. I forgot to report back after changing the fuse. I had the same problem and vaguely recalled solving it before so came back here. I've blown the fuse again!
Bullzeyebill
CA
After all of this time the question was not asked, 'what brand, model DMM are we talking about"?
seanspotatobusiness
It's a Precision Gold Academy PG 10B. I've had it since I was a kid; maybe 15 or more years. They still make them, it seems with very little change in appearance.
