LED headlamps with no washers which means no more than 2000 lumens on low beam
It means no more than 2000 lumens
from the light source. It does not mean no more than 2000 lumens
in the beam. The non-imaging optics used in LED headlamps are generally a whole lot more efficient than the imaging optics used with previous light sources, too, so a greater proportion of the source lumens wind up on the road. A good headlamp with an HB4 halogen bulb producing 1000 lumens might put 450 lumens on the road. A good headlamp of the same frontal dimensions, with LED light sources producing 1000 lumens, can put more than 750 lumens on the road.
We're getting close to the wall with intensity
Not yet, we aren't really.
Koito makes reflectors for multiple Japanese car manufacturers, their BiLed projector (which can be purchased and retrofitted in many reflectors) makes just 2250 lumens (...) glare limits. The latter ones are so strict in Europe that some manufacturers aim their headlamps lower to pass the homologation tests.
This is not how it works. The glare limits in the beam specification are met by engineering the optical system, not by aiming the headlamps. The aim specification is separate. In Europe the photometric spec has a strict limit on low beam glare
and the aim setting for the homologation test is specified in the regulation. It is not at the manufacturer's (or anyone else's) option.
Phantom23, you are (still) conflating bits and parts of things you clearly do not understand, and you're (still) throwing around lumen numbers you've seen -- as on that picture you saw of the Peugeot headlamp -- without comprehending them. Will you please make an effort to understand the subject better so the advice you give and the commentary you make will be at least somewhat based in reality? There are good resources for doing so, many available at no cost, and I know you've been pointed at some of them at least. You are of course welcome to an opinion, just like anyone else, but questions like these don't call for opinions, they call for facts, and when someone asks a legitimate question out of ignorance or misinformation, it really does the opposite of helping (anyone or anything) when more/different ignorance or misinformation is given in response. Thank you.
