I only have one conversion pill left. Don't think there will be any more made.
Is it still for sale? How much?I only have one conversion pill left. Don't think there will be any more made.
Datiled already has copper pills for his engines!
....Have an idea for a high powered build for a sundrop i am thinking..
Am thinking of boring the haiku to accomodate a 18350 cell instead, can squeeze out even more lumens
The threads would get very thin
I think that @Moddoo still has a couple of compatible 18350 "splitbody" tubes available for sale here, though.
Not sure about shipping international, but you might be able to work something out ....
Looks like McBrat has sold his last triple conversion pill! If anyone else wants to do this mod most probably have to settle for his standard copper pills and buy a copper rod and cut it to size and stack it on top, would work well too
I see someone has bought his Alum EN plated EDC
Hmm will check it out also.. 16340 is good but it lacks the punch the 18350 gives, of course 18650 is even better but that would be a different class of lights..
my prototype was copper washers stacked...
The shop that made the pills can make more, but I don't know what the cost would be on a very small run. but at least they already have the CNC file for them....
Ah, but the problem is the light in question is no longer being producted (extinct!!), so demand on it wouldn't be very high.. save for a few crazy modders like us..
My prototype was our 1 cent coins, soft and conducts heat well, and can be filed and flattend to fit anywhere
Hint :
Actually i have another solution for this.
Buy extra copper triple MCPCB, file the top layer (red coating side) off then solder a few pieces (depending on the height needed) & you will have a nice solid chunk of copper heatsink with a hole in the middle already.
The thing about our 1 cents coins are that they are copper coated zinc.
Yeah but a bit wasted to use those triple stars.. I even cut them up nicely so I can use it to house 3 separate LEDs (on small builds).. best would be to go to a hardware store and buy a copper rod, cut it down to size and drill a big hole in the middle
Gonefishing has lowered his price of his mac tri to 6XX.. can't believe it.. if he had posted it 1 month ago in dec I would probably have bought it.. and it comes with a FET + 1 driver and drilled optics
But the one I bought now is really the one I want, and modding is the fun part of this hobby!
if you have a copper pill in a regular Tri, you can drive those harder...
Ghos, nice work! I think mine may be direct drive now... not sure, I should test it. I had a qlite 3.04A driver, but did something bad with my soldering iron, and it's just a single mode, triple XPL, and it's bright!
