Tiresius
UPDATE: My brother's lathe is golden now. One gear's (one) teeth got a little chip on it. The brass pin that held the rod that drives the auto feed broke off so he had to get a spare and fit it snugly. The threading tool was completely destroyed and there was a few chips on the center chuck's body. It's mechanically functionable without any problems. A little lube and it's good.
Here's my crappy rendition of the McClicky mod I made today in just under 1 hour. Please feel free to laugh as I already did at myself. I started out with the clicky's nipple. Then bored the outer part based on how long the threading body part was. I tapped in the clicky as they fit very tight from the nipple to the body. I was slightly off from making this thing completely flush.
Why no threading? The clicky I got was not exactly a perfect circle. At one point, it was 17mm. At other points, it was 16.8mm. At 20TPI, it's big enough to make a difference. Also, I have no more internal threading tool
Enough said, here's a few short photos:
The upper part shows how tight it seats on the nipple area:
Just ever so slightly from making it seat flush:
And lastly, I had to solder the two points together with a little flux and a hot iron. It'll solder together once you have adequate flux :
