rrego
I picked up a yellow G2 that came with a notchless bezel ring. I compared it to my other G2s, the ring on this one has a slimmer profile than the others. Does anyone know how to remove these old style rings? I am wanting to remove the plastic lens and put in a glass lens.
I noticed that when I was cleaning it, I gave it a good scrubbing with dish soap, and water got into the head. I dried it and noticed the bezel ring is ever so slightly off of the lens (I can move the lens around with my finger), causing it to not be water tight.
The plastic lens is in perfect shape, so if I can't get the ring off, I'll just be sure to use it in dry conditions only and not expose it to wet conditions.
I wanted to run a 3.7 volt incan drop in, but that will surely melt the plastic lens, reason for wanting to change it to glass.
Thanks for any tips/ideas you might have.
