gav6280
Planning on getting myself a Tektite LS5 from Divelife.
The Blurb
Computer machined from a solid bar of Aluminum, the Expedition LS5 provides blistering 200 lumen power for those needing extreme ruggedness in a C-cell size flashlight. This Luxeon III Star LED flashlight utilizes specialized optics to produce an ultra-tight 10-degree beam pattern,with light output equivalent to more than 40 regular LEDs. This "spot" beam pattern enables the Expedition LS5 to cut through fog and smoke. Double O-ring seals give this waterproof light an underwater depth rating of 1,000 feet. Uses 3 C-cell batteries that last 5+ hours at full power with an additional 10 hours of usable light. Comes with an adjustable,cushioned wrist lanyard and rubber glare guard.
Specifications
Do you think simply bonding on an aspheric lens might make any appreciable difference?
The Blurb
Specifications
- Depth Rating: 1,000 feet (300 m)
- Lamps: Luxeon III Star LED
- Lamp Life: 10,000+ hours
- Burn Time: 5+ hours at full power
- Power: 200+ Lumens
- Batteries: 3 C-cell Alkaline
- Materials: Anodized Aluminum and LEXAN®
- Dimensions: 7.75" (20 cm) L x 1.9" (5 cm) Dia.
- Weight: 1.13 lbs. (0.51 kg)
- Individually serial numbere
