Finally got time to play with this pill. I picked up a 4D Mag from Home Depot for $15.97 with batteries - very good deal. The only light that I have to compare the Maxstar5 with is an Elektrolumens Blaster JR. This is a 3W direct drive with a 3AA to 1 D adapter. This is a great light and is very bright. Of course it goes through the 3AA's fairly quick - never checked the run time but it's probably 2 hours or so. I wanted a light that had a long run time, great throw, and brighter than my Blaster JR. I use the Blaster JR. when I let my dog out at night - we have a large back yard and I sometimes have to locate him to see if he is responding to the " come" command. I think he has lost some of his hearing. The Maxstar is brighter than the Blaster. I can get a tighter hot spot with the Maxstar. When it get's dark I fully expect the Mag to have a great throw. I did expect the Maxstar to be brighter since I thought it was going to be running at 5 watts, but if it can maintain the initial brightness for 20+ hours, then I am happy. It would seem that the run time graph supports this. As far as color I would say that the Maxstar looks white, but if you compare it side by side with the Blaster JR., it is more purple in color (but not by much). I measured the 4 D cell Duracells at 1.57V each, and 6.30V stacked (no load). I measured 508 ma using the tailcap method. This comes out to 3.20 watts. The Blaster JR. measured 788 ma, with the 3AA to 1D measuring 4.18 volts (it drops fast with direct drive). This gives 3.29 watts. If I have the Blaster aimed at a white wall at about 6 feet it has a big hot spot - i would guess 12" or so. If I adjust the Maxstar to equal the 12" hot spot I would say that they are both real close in brightness. If I adjust the Maxstar to a tight hot spot 6-8" and move it back and forth through the Blaster's 12" hot spot it will cut right through it brightness wise.
So the Maxstar should easily out throw the Blaster JR. which is what I am looking for. Did I expect more? YES. Is it worth the $52 investment. I believe the answer will be a definite YES with the predicted and now graphed run times.
