Is a new android app version out today?
I can't check, i am too busy with bugs looking.
Yes, but I haven´t tried it out yet.
Edit: Tried to make a new programing two times, crashed both.
in firmware 1.03 this was fixed.
Do we have access to 1.03? I know it has been remove some days ago.
Because the Opus has a crappy circuit and doesn't use real DC, but pulsed current, which makes accurate measurements very difficult.I try to figure out why the Opus gives a higher capacity than cell rated instead of the mc3000 that gives more logical measures.
You can try DEX for logging. Instead of PCLS.
Shame on the squirrelWhat is DEX and PCLS? I can't recall their meaning as I've seen many terms using the same abreviations.
Both are silly yet practical abbreviations, the manual is full of such, introduced by me.
PCLS = PC Link Software = the official pc link software made by Sky for mc3k. i think the original name is mc3000 monitor. logs with 1Hz and data can be trusted.
DEX = DataExplorer = the third-party open project freeware pc link software which includes growing support for mc3k. logs with 1Hz.
My focus of testing and finding bugs has been 98% on the device firmware so far
I finally found and related the abbreviated meanings. I sometimes don't rely on abbreviations. After many years of using various same abbreviations with different meanings. I sometimes have difficulty remembering them and sorting them out.
I already ordered a BT-C3100 so I'm going to use the Opus for a while to determine charging functionalities and behaviors. The programming features of the MC3000 has advanages of modifying other charging parameters while providing a better battery analysis. My solar charger has similar functions that allows a user to view, modify and download charging paramenters from a connected PC. Which I find beneficial while trying to maintain batteries.
If the BT-C3100's fan becomes a problem I'm considering a different type of 25x25 mm replacement fan.
Do you know of any specifications such as fan type, voltage and amps for the Opus MT-C3100 and SkyRC MT3000? Fan type and construction makes a difference in how well a fan performs as well as dB noise factors.
When I bought the Opus, I bought a spare replacement fan. I have no problem with the fan.
If you want to compare the Opus in a charge tes C>D>C with the Mc3000, you could go to this thread:
https://www.candlepowerforums.com/threads/389732
Start at #255
Yes.Will this do everything the la crosse bc1000 can do? Just bought the bc1000 and noticed it gets to hot and pauses. Then I discovered this forum. Debating on returning the bc1000 and buying this is it will do everything the la crosse can.
Yes.
And then some.
It's the most advanced charger on the market at the moment I believe. Consumer charger anyway.
