stephenk
liteshop.com.au may be cheaper when they release the product.$149 australian from batteryworld
thanks stephenkliteshop.com.au may be cheaper when they release the product.
I know you like the manual, but do you have any thoughts to share on the charger itself? Thanks.i should edit this post and add a few remarks about some points in the review
I've also seen a much lower price from GearBest if you can live without an Australian warranty and plug.thanks stephenk
Do you find these values superior to the in slot measurements of the MC3K?
They will be more consistent due to the four terminal connection, but the calibration do not look as good as the Sky.
If charging 18650 batteries, is this charger better than the Nitecore D4? One difference is charge rate - It looks like the Xtar can charge 4 18650s at 1 amp, whereas the D4 would be at .375A or 2 at .750A. Any other advantages? Is the D4 better in some areas than this Xtar?
If I read the review correctly, Eneloops receive a 2 hour low current top off after termination. So leaving the cells in should be fine; 2 hours after termination there is no further charging.
But does that mean that I should wait those 2 hours so the cells are really fully charged? Or removing as soon as the charger is green they're already full? Thanks guys!
