Test/Review of Samsung INR18650-35E 3500mAh (Pink)
HKJ
Copenhagen, Denmark
[size=+3]Samsung INR18650-35E 3500mAh (Pink)[/size]
Official specifications:
  • Nominal capacity: 3500mAh
  • Minimum capacity: 3350mAh
  • Nominal voltage: 3,6V - 3,7V
  • Charging voltage: 4,2V
  • Discharge current: 8A
  • Maximum discharge current: 13A
  • Charge current: 0,6C 2000mA
  • Discharge end voltage: 2,65V
  • Pluspol: FlatTop
  • Chemistry: LiNiCoAlO2
  • Diameter: 18,55mm ± 0,1
  • Height: 65,25mm ± 0,15
  • Weight: 48g ± 1
This is one of the new high capacity cells.
The discharge curves has good tracking.
At 15A the B track stops just after 2.3Ah, this is because my battery holder melts (I hope this is fixed now).
15A is definitly too high current for this cell. The cell temperature is above 75°C (25°C ambient + 50°C temperature raise). Logfile says 87°C for A cell.
On this chart it is obvious how the heat improves the performance at 15A.
Due to the melted battery holder I did only do this for one cell.
[size=+3]Conclusion[/size]
The cell looks very good, it has lot of capacity and can handle some current, but I will not recommend it above 10A.
[size=+3]Notes and links[/size]
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Compare to 18650 and other batteries
nbp
Wisconsin
Several off-topic and baiting posts removed. Let's stick to the cell in discussion please.
akhyar
Malaysia
Thanks for the test.
Is this cell fairly new as the 2 other 3500mAh cells, Sanyo GA and LG MJ1 are easily available from China/HK webstores?
