CuriousOne
- Joined
- Oct 14, 2012
- Messages
- 813
China 26650's already hit 5800mAh @ 10A discharge.
This is a 21700 cell (21mm diameter x 70mm length) that is an incredible performer, running over 20% longer at 30A continuous than the Sanyo NCR20700A thanks to its incredibly low internal resistance of 10-12mOhms. This low internal resistance reduces voltage sag, letting the 30T run for longer before the voltage drops too far.
As is typical for a Samsung cell, I consider it to be underrated due to it running cooler than others at its factory rating. I am rating this Samsung 30T at 40A and 3100mAh. Its maximum vaping amps (MVA) rating is 60A, limited by temperature.
...This is a fantastic performing true 30A cell that easily beats the Sanyo NCR20700A at both high and low discharge current levels. At moderate power levels this Samsung 40T even beats the incredible Samsung 30T, hitting harder for almost the entire discharge down to 3.2V and for a lot longer too.
...This cell delivered 3962mAh and 3985mAh in my capacity tests….
I have some liitokalas that reach 6000mAh in testing at 1A, they are labeled as 5100-5400 (various types).The 26650 size seems to be topped out at 5200mAh, with apparently no one working on improving capacity further. Samsung allegedly has a 5300mAh mid-power 21700-53G cell planned for future production, which could make the 26650 an oversized and obsolete form factor.
