Test/review of Varta LongLife C 4114
HKJ
Copenhagen, Denmark
[size=+3]Varta LongLife C 4114[/size]
Official specifications:
  • Shelf life: 10 years
  • Nominal voltage: 1.5 volt
  • Typical capacity 7600mA (Discharge with high resistance)
  • Permissible temperature range: -10°C ~ 50°C
  • Chemistry: Alkaline
This is a standard Alkaline C cell from Varta.
This is typically Alkaline discharge curves that are very depend on current.
[size=+3]Conclusion[/size]
Performance looks to be about the same as the other Alkaline C I have tested.
[size=+3]Notes and links[/size]
How is the test done and how to read the charts
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
Compare to other C/D batteries: Alkaline/NiMH/Lithium
xxo
Thanks for the test!
It is amazing how poorly alkalines do under higher current loads - looks like a Eneloop Pro AA has more energy when you get to 1 Amp.
