Alex,
It is likely that you have a joker. The McR-27 is one reflector that I have not ordered in the new -J configuration as I am not using this reflector anymore personally and don't have any call for it from other builders.
The stock McR-27 could be shaved off (rear face) by about .015" and likely get you back the tighter spot but in the PR-T head, the O-ring seal and seating of the bezel and window could get funky with the reflector droping down further into the head. :shrug:
As an update to this thread, I finally got confirmation from an employee at Lumileds that there was an unauthorized change in the slug height and that these "jokers" will continue until some time in the spring when the factory runs out of the short slugs and at which time I have been told that the next run of slugs will be back to the original height and we will be seeing LED's that look like jokers but again have a new image location on the Z axis. :green:
If Lumiled's or Future don't bother to identify this third or is it turd iteration, I will take to calling them FJ's for "false jokers" or some other f word adjective.
Now what has me a bit confused is the fact that I was told that this difference in slug height is only about .009". Now my experience has been that the apparent image has dropped by almost double this reported amount. If there is more to the change we have seen than just the slug itself, heck if I know?!?!? The reported difference seems to put these joker's at a image height very comperable to the reported K2 image location. To my simple bench tests, the K2 samples I have played with seem to fall between the joker and original LuxIII.
Dang! I confuse easily and much more of this and I will be bonding the dome to the heatsink with the LED upside down!
