Swedpat
I received Catapult V6 in neutral white a few days ago. Another great Thrunite product with the UI I really like. The tint is very good neutral and no greenish. As with TC20 I will mostly avoid turbomode because it's hard load for the battery and with short runtime. High mode is good enough and still provide impressive throw. The size is perfect in the hand and with good hold. There is one thing I reacted about, however: the reflector is pretty shallow(and not the typical thrower style of today) and this results in a wide spill. Significantly wider than TN42, and just a bit narrower than the spill of standard Maglite reflector. I would prefer a spill not wider than the spill of TN42. Not a big deal though.
While TN42 as well when it comes to size and weight is a giant in the hand the Catapult V6 is a pretty compact light possible to carry in the jacket pocket. It´s much more compact and lightweight than Olight SR52UT and with almost the same throw, so it feels like SR52 becomes a bit superfluous. Not to forget the advantage of a single battery.
But there is a thing I am a bit doubtful about: the rubber cover for the micro USB port is easy loosened by mistake with the finger and does not feel very tight. Because of this I would not trust the claimed water proofness. It does not feel like a good protection from water, and I got the same feeling with TC20.
Anyway my conclusion is that Catapult V6 is another great addition to my flashlight and Thrunite collection. Recommended!
My order of Catapult V6 also included a TI4 and two Keeppower 6000mAh cells. Good that 26650s now have serious capacity improvement over 18650s!
