srfreddy
Wow on the output-looks like the Zebralight is finally toppled for King of 1xAA output!
I don't understand why they have the PWM frequency so low on just the 2C verson, what are the benefits?
Yes, the 1A does indeed top it, although the difference isn't so great on NiMH. But the SC51 is optimized for NIMH (and 1x14500 is NOT recommended), so that's not an entirely fair comparison to the multi-battery support of the 1A.Wow on the output-looks like the Zebralight is finally toppled for King of 1xAA output!
Thanks for weighing in HKJ.The problem is when you need both buck and boost, you usual need two different circuits for that. A few chips has combined it in one circuit, but they do not work down to 1 volt. The best wide voltage range circuit I have measured on is the ArmyTek.
That's an interesting theory. I have noticed in the past (and can confirm with the 2C as well) that the lowest output modes are where the PWM is most distracting. In fact, prior to measuring it, I would have sworn that the Lo mode had a lower PWM freq than Med/Hi - but they are all the same. It is interesting that our relative perception varies with the shape of the precise PWM pattern (i.e. for a given freq, the shorter duration the light is "on" in the PWM wave - and the lower the corresponding perceived output - the more relatively distracting). I can also vouch that the PWM seems more noticeable to me in my peripheral vision that central, supporting your rod theory.I assumed 100Hz wouldn't be visible as flicker and thought that it must be lower (like 50Hz) but I was wrong. It certainly looks less to me.
I'm going to make a guess as to why the lowest PWM mode is the most annoying and say that the total light output is low enough that the eyes rods are being used and the PWM rate is too low to maintain persistence of vision and reach the flicker fusion threshold. At the higher levels the light output becomes high enough to bring the cones of the eye into use which have a higher persistence of vision (1/20 second) and therefore lower flicker fusion threshold.
Some quick research into this reveals that some of the more sensitive parts of the eye can detect flicker up to 250Hz !!!!
Ah, that's a little more doable - but it is still not a popular solution.
I would have leave this to the circuit experts to explain why, but I believe the real problem comes when you try to support 2x 3.7V Li-ion (which can over 4.2V to start, meaning you need more than 8.4V max - typically 9V to be safe).
If you just wanted to support 2x 3V CR123A, you could go a lot lower (i.e. a little over 6V, which is apparently easier to do in a multi-power circuit - especially regulated). But the few lights that have done this (the Tiablo A8 comes to mind, but I think there are some new Xeno lights as well) don't seem to do sell as well as those with full multi-power support. The problem seems to be that fresh CR123A cells can be a little over voltage under load, so you need to run them on a lower mode for a few minitues to drain them down to the point where they will activate on Hi. And of course, there's a risk someone will pop 2xRCR in there and blow the circuit. So, on the whole, manufacturers prefer to go with full 2xRCR support, which requires a whole new circuit.
I've had the 2C for about a month now.
First, I don't notice the PWM at all! Second, on mine, the hotspot has a light-brown donut when white-wall shining. Third, the tail-standing is quite wobbly.
But wait!!! It CAN take RCR's can't it? The problem I've been having (for which I posted in a thread all its own) is that when using 2 TrustFire RCR's, (and after the light goes abruptly dark), from using it for several days, 1 of the cells is COMPLETELY DEAD (ZERO VOLTS). Meanwhile the second cell is STILL right around 3.7!!!!!! oo: I've tried this on 2 different sets of cells and it does the same thing. Right now, I'm using it with AW's, to see if it behaves the same way.
I'm wondering what the heck is going on with that!! :thinking:
Thanks for posting. Although a number of us find low freq PWM quite nauseating, many people report not seeing it. Another light that produced a lot of discussion was the Olight M30, which had 100Hz PWM on its low modes.I've had the 2C for about a month now. First, I don't notice the PWM at all!
At first blush, sounds to me like a battery problem - assuming it is happening abnormally early (i.e. is one of them shorting?). It is normal for a battery whose protection circuit trips to read initially as zero volts - but in most cases (on good quality cells) the battery will almost immediately recover over the threshold cut-off, and show a high 2.x V or or low 3.x V charge. All my AW protected RCRs have worked fine in the light, and come out reasonably well balanced after one of the protection circuits trips (with near immediate bounce-back to >3V once removed).The problem I've been having (for which I posted in a thread all its own) is that when using 2 TrustFire RCR's, (and after the light goes abruptly dark), from using it for several days, 1 of the cells is COMPLETELY DEAD (ZERO VOLTS).
Yes, it does perform the same. However, the Neutrons have a raised ring in the head, around for the positive contact plate (i.e. to physically prevent reverse-polarity). The new TI 3V 14505 have a shorter raised nipple at the positive terminal than standard AA or 14500, and I was unable to make contact on mine without using a small magnet spacer.Can I assume that one 14505 3v Titanium Innovations cell in the 1A would behave similar to the 1C with one CR123A? Not as awsome as the 14500, but not bad for a single AA light. Are there any single AA that can beat 320 lm with the 3v 14505?
No, those are correctly-labelled Mini results in my runtime graphs. My regular Quarks are all from the original XP-E R2 run, so I don't usually include the data if I have more recent XP-G R5 Mini data. And yes, 14500 is not recommended for the Mini AA (by neither the manufacturer nor myself), but it does techinically work.The 4Sevens lights are referred to throughout as MiNi, but they appear to be from the Quark (regular or tactical) series, and the 1xAA test results include 14500 data, which is not advised for the MiNi AA.
Note also that you shouldn't routinely be running cells down to the point where the circuit needs to trip - I only do it to provide comparative runtimes (but it means I go through cells a lot faster than a regular user would). Better to regular top-up of your cells, and measure the voltage frequently to make sure they remain well matched (for ex., is one of your cells self-discharging faster than normal?)
Ah, no, those are Quarks - I just didn't bother to label all the pics this time.Are the lights in the photos MiNis? That's what initially led to :thinking:.
Yes it could be the protection circuit. In the first set of cells, which I labeled 1 & 2, it was consistently #1 which always dumped first. I have not numbered the 2nd set, but it's always one over the other.
FYI, the selection of lights for the round-up photos are just to allow you to compare relative heights and widths among similar builds in the same battery class (i.e. I grab a handful of lights of roughly similar sized lights, rather than posting rulers, etc.). These pics are done when the lights first arrive, and don't correlate in any way to the runtime graphs. The runtimes graphs are generated at the very end of testing, and I select traces of similar emitter/output levels for the best visual comparison.
This is why I don't report the Quarks on the graphs, since my older XP-E R2s are not indicative of the newer lights with XP-G R5/S2 emitters. But the Quark exteriors haven't changed much, which is why I used them in the round-up pics in this case (i.e. fairly similar looking to the Neutrons).
Possibly, but I doubt it. If it was just a question of the protection circuit in the head of the protected 17670 not making it, then I could see boring being being feasible. But in this case, even the back end of my 17670 won't make it in, meaning you need to do a lot of boring. It might be possible, hard to say. :shrug:I was very sorry to hear the 2C body won't accommodate a 17670, much less an 18650; the output results had me thinking of legoing the low-V head onto the 2C body. Any chance it could be rebored to accept a 17670? (Probably not worth hoping for an 18650... how thick can the walls be?)
?(Probably not worth hoping for an 18650... how thick can the walls be?)
