I´ve been using the TN35 shining around in the garden, looking at long distans trees and used it quite alot indoors as well for about 3 months. My 2 cents are:
Minus: It´s on the heavy / large side of a flash light. It feels like you are holding a tank and you can easily use it as a weapon... It´s unconfortable to put it in your front pocket and make it stay there, not falling to the ground, when you need to use both of your hands. You don´t wanna drop this light... Using the lanyard is not an option, it´s too much weight hanging around. The spacing between 380, 950, 1600 and 2750 are too many. Why do they put in so many steps..!!! I don´t get it!!! I don´t need the 950 nor the 1600. The steps are too small... 0,3 / 24 / 380 / 2750 had been a winner IMHO and takes you to 2750 faster. You don´t want the off around max and strobe setting. It should have been. Strobe, Off, L1, L2, L3, L4 (like Vostro). Actually the strobe could have been hidden as well. If you want to put on the light without blinding your self and let the hole neighborhood know that you are out in the garden sneaking around and let them know you are a true flashaholic, you must use two hands, one holding the light, and the other press the rear button to turn the light on/off... This is not practical.
Plus: The quality is flawless. The control ring is a treat to handle, smooth and with clicks on every setting, and I love to adjust the output up and down, to suit the situation, with one hand. "Moonlight" on a light like this is to travel in 60 km/h in a Ferrari, but i love the feeling that you have the juice if you want to. The big jump between 24 and 380 is actually OK. I thought it would be a gigantic step, but nope, it´s useful when you want to peak at something on a medium distance quickly going from closer surroundings. Momentary and let you choose output before putting the light on. The tint... Oh, do not forget the beautiful tint!!! This makes you smile when you turn it on and do your little white wall hunting that you can´t resist if you are a true flashaholic. From the spill to the hot spot is even with the same neutral white color. Only Nichia can compete what I know... The beam is very practical. A large nice spill area and a lovely BIG corona surrounding the sharp hot spot. This big corona, by the way, is what make this light more useful than a true thrower. You can say it´s like a 3 layer beam very similar to the SWM D40A. I have made comparison as I own both of them.
The bottom line: As it is so similar to my other pocketable "thrower" SWM D40A, I might sell the TN35. It does not make up for the extra lumens and weight/size that I thought it would. I can sacrifice the lumens. It may perhaps reach 50-100 m extra in good conditions. But, the tint is something that the SWM neutral doesn´t even come close to… Do I have the b_lls to sell it… I will most probably regret it and miss the light… Hmmm, we´ll see.
Edit: 01-10-2014. Well... I had the b_lls to sell the TN35... I don´t really miss the light, but I sure miss the beautiful tint and the lovely beam profile. One of the best if you ask me... My hunt goes on towards a smaller MT-G2... Perhaps will the SX25L3 be a good choice for me as Selfbuilt mention to me below. The tube/size, tint and UI will fit me, but I will surely loose a lot of throw. The battle in this case goes around throw vs size... The size did matter to me after all and made me sell the light. If I can´t wear a light I can´t use a light. These last words will end my "review" of this light
