rookiedaddy
selfbuilt, which AW 18650 cell you use in your runtime test? the new 2600mAh or the older 2200mAh? according to Tiablo, they are using 3000mAh cells... i hope they are not referring to Ultrafire 3000mAh...
Sorry, I usually label that right in the graphs - all my runtimes are done on 2200mAh. I would expect proportionally greater runtime from the 2600mAh variety, but I have no direct experience of any 3000mAh cells.selfbuilt, which AW 18650 cell you use in your runtime test? the new 2600mAh or the older 2200mAh? according to Tiablo, they are using 3000mAh cells... i hope they are not referring to Ultrafire 3000mAh...
They use Panasonic 2900mAh unprotected cells.selfbuilt, which AW 18650 cell you use in your runtime test? the new 2600mAh or the older 2200mAh? according to Tiablo, they are using 3000mAh cells... i hope they are not referring to Ultrafire 3000mAh...
I just retested the light, and I get the same reading - 113.4g with no batteries installed. With a pair of surefire CR123As in there, I get 146.3g.There's a discrepancy between the manufacturer's weight specs and the weight specs reported. It'd seem more like 130g including batteries and close to 115 without.
Good question - but you will have to check with Tiablo directly for an answer. As is common on multi-power lights, the protection circuits on my 18650 cells were not triggered on either output mode. Can't say I recall seeing any signs of the low voltage warning flash on either of those runs, and I ran them past the point where you would notice visible light dimming. The only place when I did notice the warning flash was when I put in a couple of partially depleted primary CR123A cells.The manufacturer's literature claims this light to have an undervoltage warning, which would make it safe for use with unprotected cells. Does your sample have this fuctionality, and if so, at what approximate voltage does the cut-off occur?
No, I'm fairly sure that the cells will be drained well below 2.4V if you let light go. Although rarely discussed here, it seems the low-voltage cut-off circuit of protected cells often won't get triggered when run on multi-power circuits that default to direct-drive. This means you have to manually stop the run before significant dimming occurs (by that point, you are usually well below 3V and dropping fast). Simply put, you blow right past the voltage point when the circuit is normally triggered, and then continue to deplete the cell to dangerous levels (something I'm afraid I have done to my cells in my earlier days of testing).If your cell-protection circuits were not triggered, then I suppose it's reasonable to assume that the batteries were never drained to 2.4 volts or below, even with "noticeable dimming".
Do you think, since the cell-protection circuits were never triggered, that they would be unnecessary by virtue of the dimming alerting you to change cells?
I am not sure of the reason why this occurs - hopefully someone with a better understanding of the battery electronics can clarify. The A7 is certainly not unique in this regard - my runtime traces show that it is a common feature in most lights with this sort of circuit.
Unfortunately, it is rare to find a light with a well-functioning low-voltage warning circuit. Again, for reasons that are not entirely clear to me, these circuits tend to be prone to malfunctioning with early warning false positives (i.e. starts flashing early into the run of a light). I saw that in my Regal EDC, and I have seen it reported for just about every light that has one. That's why it is often removed - the Olight M20 being a good case in point (my sample was an early specimen that had it - it was soon removed from the later production runs).
Long story, but the short version is that I don't know of a 18650 light that is a consistently good choice to run safely on unprotected cells. I suspect you are likely to do best with a 18650-only light that has a dedicated low voltage circuit.
I still have the light, but don't have a lab power supply. I will experiment with one of my older 18650 cells to see if I can trigger the warning, and then try to figure out at what resting voltage/storage level it starts. I'll keep you posted.Do you still have this sample light? I was wondering if you could power it from a lab supply, and gradually turn down the voltage to see if the advertised warning strobe really occurs, and at what voltage. If it works, I want the light, and the current sale is only good for a week or so.
Just finished testing:Do you still have this sample light? I was wondering if you could power it from a lab supply, and gradually turn down the voltage to see if the advertised warning strobe really occurs, and at what voltage. If it works, I want the light, and the current sale is only good for a week or so.
The low-voltage warning flash was triggered at just under ~25% max output. The 18650 cell read 2.92V at rest immediately afterwards.
Note the warning is just 3X 1sec of strobing (with 5 secs of normal output in-between). It will not keep strobing as the run continues.
Out of curiousity, I decided to see what at-rest voltages were reported at different outputs: (i.e. I stopped the runs at these points and measured at-rest battery voltage, then re-started the runs)
50% of Max = 3.21V
25% of Max = 2.95V
15% of Max = 2.82V
