ssanasisredna
- Joined
- Oct 19, 2016
- Messages
- 457
You're making some pretty big assumptions here. Are you an optic specialist? This light uses a TIR(total internal reflection) optic, not a reflector, and not only a TIR but one with a honeycomb diffuser. Do you know for sure that the emitter size effects the beam pattern on this particular optic? Do you know whether or not the emitter is at the same distance from the optic on the XM-L2 vs the XP-L model? Do you know how the normal variances in emitters effect beam angles? Do you know if the beam angle is exactly the same on each light even with the same emitter? Do you know how the optic depth/recess into the body effects beam angle? Do you know, for sure, if the beam angle is even any different then the specs?
My standard for calling someone an expert is beyond my skill in optics. Given that I have developed custom TIR optics, reflectors, light guides and basic optical systems for illumination that are used in production, I am pretty confident to make the comments I did.
- Exact same listed X-Y angle distribution
- Exact same hotspot size at given distance
- Similar OTF lumens
- Vastly different peak candela
Something is not adding up.
As another poster has mentioned, the runtimes (stated as with a 2000mAH NiMh on their website) are "optimistic", though impossible would be more accurate.
Reality is it's $50 .... it's not a big deal, just would like to know what I am getting ..... In Advance.
