markr6
- Joined
- Jul 16, 2012
- Messages
- 9,258
I don't see Pflexpro in #22, or anywhere. Am I overlooking it? I am curious to know the poke since I was always interested in those lights and dropins.
So is the guy who started this thread bashing Fenix ever going to come back and say that he had a bad battery? I just had the same thing occur with my new Nitecore MH20GT and it looks like I need to trash that company for bad quality. Has a Nitecore is crap thread been started yet? Oh, once I slipped the new Keeppower in there it was bliss again, but I'll admit to being pissed off whne the bad battery was in there and I pressed the button and the light didn't work.
Great info and links. I am thinking of not running protected batteries since I have a smart charger and the flashlight I will end up with will have its own protection methods. What do you think?
I only owned two Fenix's. The first models that came out early on. Only problem I had was the contact plate in the taii cap coming loose, causing no light, or erratic performance. Easy fix using a needle nose pliers to tighten it back up. Does Fenix still use a contact plate that can be adjusted?
Bill
My wife is hard on lights, especially the ones she uses in and around the barn. In the past several years she has killed many lights, most by dropping them.
A couple Surefires, two Malkoffs, an HDS, and a NovaTac. There are probably others, but those are the ones we can remember.
Her Fenix TK35UE took a beating, always came back for more, and never failed her. She now uses an Acebeam K60 and a Fenix HL55 as her all around lights.
Last week I saw her toss the HL55 onto her tack box. It slid across and went off the back, dropping onto concrete from about ~36". I said holy smokes you don't treat that light very nicely.
She replied...
"It's a flashlight...I don't care and I'm sure it doesn't either...unless you're telling me flashlights have feelings!!!".
Yes Surefires are stuffed with just as much overseas parts as any Fenix only the SF bodies are made here.
there are not many US made lights anymore...Yes Surefires are stuffed with just as much overseas parts as any Fenix only the SF bodies are made here.
Ok-so Malkoff/Surefire (with the exception of a single model which will set one back over a g note) make products that in no way even approach the periphery of what the Asian makers offer and yet some will comment on the built quality and perceived reliability of one v the others-don't quite get it. As for the 'failure' rates; to be accurate not only must the number of sales be factored in but so must the capabilities-with regard to the latter-it would be similar to comparing the Model T to any late model vehicle after all they both did the same thing correct? Keep in mind this-with simplicity comes reliability, all other factors being equal AND increased performance equates to increased stress-these two facts should not be dismissed or even argued.
