TigerhawkT3
Cool mod! Where'd you stuff the current limiting resistors?
This?You know there's a 3-Rebel optic that has a matching 3-Rebel Star, right?
It was intended for the RGB market but surely would kick *** in the white flashlight market too!
He said it's direct drive and starts around 733mA with full charge.Cool mod! Where'd you stuff the current limiting resistors?
ha ha ha, i thought that also!Doesn't it look like the hotspot has a smiley face in it?
This is great - I've been knocking around the idea of trimming off the back of a reflector and using a cluster of rebels in it...you've brought it to reality! =)
If you moved the Endor board up or down a little, to slightly defocus, do you think the beam would smooth out a bit? I'm thinking about having an Endor mod done in an HDS and trimming the back of the reflector there too.
The current hogging issue...this is a problem with all Endor boards, no? B/c they're all parallel? Or can it be wired such that each led gets its own drive?
I have all my parts now... And several questions
The rebel star is too wide to fit into the C2 heatsink. Did you just grind it down so it would drop in? I am thinking of just using a Dremel to 'help' it fit.
Since the star is larger than the original Cree "star" it overlaps the holes for the wiring. How did you get your wiring from the underside to the top of the star?
Did you raise the star or stick it directly to the stock heatsink? Or did you just unscrew the heatsink slightly to raise it?
I'm also replacing the stock driver board with a tri-flupic so I have some modes... But now that I have all the parts, i've found the stock driver board is 18mm in diameter and the tri-flupic is 20mm in diam. This should be fun to overcome
Thanks in advance
how is it with the flupic in there? i'm curious as to what effect this has on current and runtime. any idea what youre getting to each emitter?I finished it and it works, but my reflector issue is much worse than yours. I have a BIG dark spot in the middle of the beam which I could only reduce slightly by unscrewing the pill to raise it. I ordered a 36mm x 40mm FL aspheric from surplus shed to see what that does. It will be well out of focus so it should just be a wide beam of light, like when you screw an aspheric Mag head all the way down. I guess i'll see in a couple of weeks when it arrives I'm just using it without any reflector for the moment because the beam bothered me so much.
Unfortunately, I can't measure the individual current draw... The star was hard enough to solder to the first time, i'd rather not do it again. The total current draw, at the tailcap, on the highest setting is about 2.1A. The circuit didn't like me measuring the output, it would power up for about 3 seconds and then turn off. It works fine with the tailcap on though. It also wouldn't let me change modes while measuring the current either.
I have the flupic set up so it turns on in HIGH, then second function is set to the lowest possible output. The low level is more than enough to see around my shed. I'd love to know what the current draw of LOW is.
