Tritium slot machining
Status
Not open for further replies.
precisionworks
Benton Illinois
Re: Tritium slot machining & installation
How do you take the photos with the trits so well lit?
Thanks Matt :)
Upper image is ambient room light. Spot metered the wooden background & exposed at f/16 for 1 second at ISO-200. Lower image is in the same location but totally in the dark. Again f/16 & ISO-200 but the shutter was open for 90 seconds which over exposed the trits. A McG SunDrop (set to medium) was blinked on for 2 seconds to pick up background details.
Upper image took one attempt, lower image is the last of six attempts. All the others were catch & release :nana:
The 60 second exposure shown below is technically correct for the trits but the background is less than exciting:
Image-9853934-155619734-2-Web_0_564b91fd791c52df2333c5ea21bd8e90_1
Mattaus
Brisbane, Australia
Thanks for the explanation Barry. Now I know what to do with my own GITD stuff. I was mucking around with long exposures but didn't think to quickly shine a light to bring up other detail. Would be easier with my DSLR but seen as I sold that a while back I will have to make do with the old point and shoot on 'bulb' mode.
precisionworks
Benton Illinois
A Mac's Custom being machined for 2x6mm trits:
Image-9853934-155749874-2-Web_0_d1b0b359c51e329c05d7bf480ef58fd5_1
Close view of slots:
Image-9853934-155749877-2-Web_0_39b7bb4881b7fa94a567e6de75cff4f6_1
This image makes the slots look pretty big but they're about the size of a grain of rice.
Image-9853934-155755197-2-Web_0_1f5d613220067aa6ff575993462f3eba_1
Image-9853934-155749879-2-Web_0_ca479b9c3521472eea2b0f1173d175eb_1
Image-9853934-155754906-2-Web_0_cf185f5042467c7155b291f2352e9085_1
Nine trits in total & five are visible most of the time:
Image-9853934-155749880-2-Web_0_1973583437489d8f21a176b517633536_1
Image-9853934-155749882-2-Web_0_7621d57402bb0bc8a5f148d67672873b_1
Henk_Lu
Golden Cage
So many countries have blue, red and white (only?) in their flags? Wow...
Those two lights look great, whoever gets them is a very lucky man. Yes, for sure it's a man, no woman would be mad enough to have 9 trits in a Mac's body and 16 in a Haiku! :devil:
Thanks, Barry! :thumbsup:
precisionworks
Benton Illinois
I'm glad that you like them :)
Each slot required 20 milling passes (500 in total). The small end mill is lowered only 0.1mm per pass which keeps the chip load on the tool at a moderate level.
I'll be eager to see images after Step 2 & Step 3 are completed.
... no woman would be mad enough ...
Please don't tell that to SMarkum. She likes the glow tubes as much as you do :devil:
precisionworks
Benton Illinois
A 1.5mm vial needs at least 1.7mm slot depth so the trit can rest slightly below the surrounding surface - this allows a tiny amount of Norland to cover the trit & cure out perfectly. If you have a micrometer (or have a friend with one) measure the thickness of the brass "button". If it measures out at 1.7mm (.067") or greater it can be slotted. Impossible to tell from the photos I've seen but it looks like it may not be thick enough.
ZeroRes Shorty info.
Henk_Lu
Golden Cage
My Haiku and Tri-EDC just returned to me and I installed the trits. :D
Thanks Barry for the perfect work, all slots are where they should be and they are all exactly the same, in one word : perfect! :cool:
More pictures in the trits-thread in the collection section...
precisionworks
Benton Illinois
This C2 received 2x12mm on each side of the clip, 2.5x25mm on the opposite "narrow" edges & 2x8mm on the tail collar.
Image-9853934-158276033-2-Web_0_f6caab5c7612213f027a9c5a4ac7bd8a_1
Image-9853934-158276036-2-Web_0_52729bf09778e03b8b2cd593a283f9cf_1
Mattaus
Brisbane, Australia
I didn't realise that the C2's had a narrower edge on them....my brother has his C3 now so maybe I should go have a look for myself lol.
Nice job as usual Barry. Really adds to these lights!
- Matt
precisionworks
Benton Illinois
The "wide" corners are those on either side of the clip & the narrow edges are the other two. Width of the edge is right at 2.5mm so a 2.5mm trit will just fit and barely cut the corners back. To place the groove dead center on the edge means dialing in to +/- 0.5°. If the slot is off center any more than that it would badly.
Image-9853934-158636778-2-Web_0_2238901689ff3d375b08a2343bc71414_1
Lolaralph
Pennsylvania, USA
I hope this is the proper spot for these questions, I have an aluminum V10r, I would like to have three trits installed in the cooling fins, what is the cost of the drilling and installation, what size trits do I need to get, and is Norland used, or do they float in the holes,thanks
precisionworks
Benton Illinois
I hope this is the proper spot for these questions ...
This is a perfect place to ask.
The trit size is 1.5x6mm and those are available (AFAIK) only from Steve Ku for $8.50 each. More info in Post #1 in his thread in The Marketplace: http://www.cpfmarketplace.com/mp/sh...-V-series-titanium-mods&p=4609924#post4609924 Norland is not used as the trits are held captive when the head is put back together.
Cost to disassemble the head, drill three holes, install your trits & reassemble is $35 + $6 return shipping. NOTE: this pricing is for the V10R Aluminum model.
SPNKr
Just a quick question, do tiny tritium beads about 2mm or less in diameter exist? I'd like to install a glowing thing on a AAA light but it doesn't have much space for a vial.
JMP
Or ask Steve, I noticed a post awhile back where he interesting sizes.
(Edit by PW - the quickest way to contact Steve is [email protected] )
Lolaralph
Pennsylvania, USA
Precisionworks,
thanks for the info, in your opinion, are the 6mm trits a necessity, or is it possible to use 5mm ones, and if so what would be the difference on the finished product. I'm trying to determine which trits to order so I can proceed with this project, thanks again
thanks
precisionworks
Benton Illinois
There are two really good reasons not to use the 1.5x5mm vials. First is that the space between the upper & lower fins is 5mm so the 5mm vial does not extend into the head fin. Since the trits are no longer captured they will need to be set in place with Norland. I've done this on a titanium head fin & the Norland is almost invisible ... but it will probably show against the matte black finish of the aluminum light.
The second reason is that it doubles the amount of time needed & that would make the cost $70 + $6 return shipping. Unless Steve has no available 1.5x6mm trits they are the best ones to use. Also, since no Norland is used for the 6mm vial you can change colors at any time you want.
Status
